Fuel D531, no spacers, TrailBoss stock lift
20x10, -12 offset, 305/55 ridge grapplers. Looks so much better. ....Also....no rub, no trimming
Edited by Memphis87
Busy day added a craftsman toolbox for all my crap
The three ton floor jack and toolbox is already loaded
Ready for baseball [emoji461]️ tomorrow
Also had to put on a gm-trucks.com decal
Next mod is bent visors once I can roll the windows down
Ryan B.
8 hours ago, Memphis87 said:
Very close fit though, will be adding .25inch spacers
If it's not hitting the caliper now, it's never going to....no need to introduce unnecessary spacers into the equation if you don't have to.  Drive that sucker!
It’s just a scary sight lol. Maybe I’ll hold off, I don’t think I’ll like the look if they stick out more. Just glad they fit though
Installed a leveling kit and ceramic coated with Carpro C.quartz.
Edited by jamez74
  • Like 5
What did you go with 1” or 1.5”?
1.5”
Mods so far:
Tinted all windows
Stubby antenna
Soft tonneau cover
Removed some emblems from the tailgate
Black GMC on grille
Replaced license plate lights with white LED
GM-Borla exhaust installed
Next up is some PPF, ceramic coating and CAI
  • Like 3
5 hours ago, tallspawn said:
Mods so far:
Tinted all windows
Stubby antenna
Soft tonneau cover
Black GMC on grille
How is antenna  on reception
did you use anything special to remove emblems
were did you get white LEDs
How's Borla sound
Mods so far:
Tinted all windows
Stubby antenna
Soft tonneau cover
Black GMC on grille
It’s hard to tell, is that Dark Sky Metallic? Maybe Smokey Quartz?
How's Borla sound
Hey! I'll check the antenna on my way in tomorrow, I don't listen to FM much but I'll let you know.
I used floss and Goo Gone for the small Sierra, fishing line and the 3M eraser wheel for the large GMC. I used a heat gun as well (very carefully). The eraser wheel is awesome, just don't burn your clear.
The LEDs I got spares from a buddy but here they are on Amazon...AUXITO 194 LED Light Bulb 6000K White Super Bright 168 2825 W5W T10 Wedge 24-SMD 3... https://www.amazon.com/dp/B071LHP5WP/ref=cm_sw_r_sms_c_api_i_Mag9CbD64FR0C
I'm loving the exhaust, it's very quiet at idle but sounds great when you get on it. Much deeper sound than my Flowmaster 40 series I had on my previous truck, even though it was louder.
It's Smokey Quartz, I'm really liking the color shift or smokey effect it has.
New wheels.... Hated the fact that GM made the AT4 all black then put silver/grey wheels on it...  Vision 18 x 8.5  0mm offsett (to clear the calipers)
I still need to custom paint the chrome center cap.
I've also debadged the truck...  painted the exhaust tips, and will be installing a 2" level and 3" block kit this week..
In place of the chrome AT4 badges I'm going to have some vinyl graphics in the same design in dark grey and red(to match the rims, more metallic looking red ) for the oem location on the doors only.  tailgate will remain clean... It looks great blanked out...
Flowmaster 40 muffler
waiting for my magnum lo-pro headache rack to arrive as well...
Edited by NHAT4
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 489 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
