Added a few more updates and this will be it for a little while.  Bought some overlay stickers for my GMC emblems and a Superman hitch cover.  Had the overlays on for about 3 days now and they seem to be holding perfectly.
  • Like 3
Vent visors well 3 out of 4. One was cracked in the packaging [emoji35]
Ryan B.
Traded in my black LT for this white RST. Gonna miss her but just couldn't resist. Went to the tint shop the next day for 5% on the back and brow and legal on the front two. Transferred the led bulbs for the license plate and reverse light from the '16. Sadly my Hostiles wouldn't fit on the '19 with the big boy calipers, not without spacers...
  • Like 4
Where did you get the overlay? Would be Sweet it it was black with red trim
2 hours ago, Philipgonzales3 said:
I did a thing today.  Added the chrome lettering in the tailgate.
Very nice ?. All you need now is chrome wheels ?
Found some diode dynamics license plate bulbs in my toolbox today so I had to swap them
Half done
Ryan B.
That's a good idea!  Haha initially I hated the chrome.  But the more I had the truck (a whopping whole month) I couldn't come to wrap the chrome.  I'm starting to like it more and more now.  I kind of think it looks good and I'm becoming less of a fan of the whole blacked out look.  Especially on rims and tires.  It turns into one big black shadow of a wheel well.  I think for my wheels I will go black and silver though for some contrast.  IDK just thinking out load here.
Installed tonneau cover today. The wheel liners are a PITA. Only got one side installed. Next up is LED’s
  • Like 3
looks great. I'm undecided on a tonneau cover or backrack.
I'm waiting on my wheel well liners from the dealer to show up too.
really considering blacking out the chevrolet and possibly black emblems
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 489 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
