7 minutes ago, Trailboss91 said:
295/70r18 Falken Wildpeak AT3W tires, 34.3” diameter with no trimming needed. No level as well.
Nice!  Not a Trailboss, right?  I'm considering tires/rims and was considering the Wildpeaks for a)lower price than Nitto/Toyo and b) to be different than the herd.
*Edit* - Your username is Trailboss91, so probably a TB*
Edited by cltsig
Ya its a trailboss, I just took off all the badging outside of the Z71 logos. This is the back with the Chevrolet insert. The Falkens ride super smooth compared to the Duratracs and way less road noise with a more aggressive tread.
Why did you pick Falken's over Nitto, Toyo or anything else available?
Honestly more budget friendly. I paid $930 for the Falkens where as your looking at $1200 plus for Nitto and Toyo. I did a ton of research and the Falkens had great reviews, offer the biggest tread depth of all LT AT tires and a 55,000 mile warranty which is one of the highest out there.
Are they E-load? does it ride more harsh then the duratracs? these are the exact tires I want to buy
They are E-Load and so far (only had them put on this morning) the tire noise is not even noticeable compared to the Duratracs (haven't been on the highway yet) and they ride much softer than the Duratracs. This is with 40 PSI in the tires.
Looks bad ass! What did you use to back the grill to get that color?
I got my Falkens 295/70s for $200 a pop at discount on memorial day weekend.
Edited by Dmart
What steps are those? They look like the ones I put on my f250 I had before I bought my TB. love those steps!
No running/scrubbing, no mods, nothing?
Beauty truck, love that colour.
No mods or anything, fits like a glove. Probably could go to a 34.5” but anything more than that and you would definitely have to do some trimming.
Trailboss 2" lift
Craftsman tool box
22" 2019 Dodge Ram wheels (1/4 spacers in front)
Running boards
Cut muffler out and put in straight pipe
LLJ Customs Trailboss sound package
-JL Speakers and Subs
Next up:
Meatier tires
Finish hard wiring Dashcam
Figure out best way to get to tweeters
Patiently waiting for some tow mirrors (GM releasing some?)
1 hour ago, drewbiehd said:
Trailboss 2" lift
Craftsman tool box
Running boards
Next up:
Meatier tires
Do you know that using 1/4" spacers your wheels aren't hub centric anymore? Not a good thing.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
