17 hours ago, MTindall said:
285/65/r20 Nitto Ridge Grapplers - No lift - No spacers - Stock wheels
That's 34.8" Diameter
It fits - no rubbing
119601610_10103094326826642_2574998786700707022_n.thumb.jpg.e92058a3486a344eca379805f63bd2ef.jpg
Looks great!  I am going to leave my at4 as is without a level or lift.  Can anyone compare the Nitto Ridge Grapplers to K02's?  I had K02's on my '18 and liked them.  Never had the NRG's.
I had K02s on my last truck and I hear slightly less Road noise from the NRGs.
That being said - there is no guarantee the noise insulation on the trucks themselves isn’t different.
119510270_10103094312465422_3186227812565143886_n.thumb.jpg.d95c1e6af690300bba934a5f7d867ce3.jpg
Why would some AT4s come with 20s while others come with 18s? Which package dictated the difference? I have the AT4 with 18s and alot of posts are of 20s...[emoji1745]
Sent from my Pixel 4 XL using Tapatalk
18s are OEM standard 20s are an OEM option
Thanks!
On 6/19/2019 at 6:01 PM, Canmaverick said:
Just picked up My new At4! And loving every minute of it!
20x9 Fuel’s
275/65R20 KO2’s
Did u throw a lift/ level kit on this. Or is this factory??
I've read and read and I am still unsure.
I know I want to go with BFG KM3's on my bone stock 2020 AT4. IN 285 width they only come in 55 ratio which I don't want because I don't want to go smaller. I can't decide if I should just stay with the 275/65/20 or try the 295/60/20. Even the stock 275/60/20 Goodyears are only about 5/8' from the control arm.
I read a lot on here before buying wheels and tires but never found exactly what I needed, so I thought I'd post my results for someone in the future.
I didn't want 20x10s because they stick out so far and because the tires always seem to rub. I did wanted to get out from under the wheel well a LITTLE, but was limited in wheels that I liked and available offset. Decided to go 20x9 +1mm offset.
For tires I wanted wider, and a little taller, but wasn't obsessed with max height. I don't like when tires are stuffed inside, and I HATE when tires rub. Why spend $50k and then have tires grinding into plastic or worse yet, cut your truck up to clear tires?   Ended up going 295/55-20 BFG ATs. I could have possibly run 295/60s, but was not willing to risk rubbing and no returns once mounted. I've seen others run 295/60, but not on a +1 offset.  Now that I have these in there, going 295/60 with this offset would have likely rubbed.  285/60 was also an option, but quite a bit more expensive and like I said, I cared more about width than height.
End results are great. No rub and has about 1/2" clearance at full lock leaving room for articulation off road with no run. The +1 offset left plenty of room for the upper control arm. Tires are about 1/2" outside fenders.
Mileage took a hit with these heavy ass tires, but I'm pretty happy with the look.  For reference, this is a stock 2019 AT4 with a rough country front level kit.
IMG_20200925_183201.thumb.jpg.fcc911cd87c37d8aeaa1a1bf4aa39fd7.jpgIMG_20200925_183237.thumb.jpg.0369d9156c110d30e7f0cf28f5b0a1ee.jpgIMG_20200925_190153.thumb.jpg.5b56b9f081783179fda4431ac88448df.jpgPXL_20200926_204049136.thumb.jpg.168cd917a28406f9de27b40e61d3ffa2.jpgPXL_20200926_204108906.thumb.jpg.ee0d3402b3baed00263ee8d504f63d71.jpgPXL_20200926_204128110.thumb.jpg.7764768842b7de68162501d62ef5e82d.jpg
IMG_20200925_183147.thumb.jpg.b877d7397f5b32cfedd63e31b569c474.jpgIMG_20200925_143044.thumb.jpg.2d6b8674d5c2f42d3dfe3eda41dca08f.jpg
From what I'm reading on here and a FB group, it seems that no one is having a problem with the Motofab 1.5 lift. Has anyone experienced an issue? Like ball joint,etc.
I have had the 1.5” level for a year now and about 12k miles. I would still like to upgrade the UCA just because of the failure’s I have seen on FB but you are correct all the one’s I have seen failed are 2” level spacers which is what may be helping my controls stay okay so far. Hope it stays that way until I upgrade
I've had mine on for a while now, almost a year and a ton of miles... with no issues. For sure the ones I've seen are 2inch RC ones. Only 2 or 3, but there was also a guy with a completely stock truck with an issue. About to need tires and was about to go a little beefier ones.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
