7 minutes ago, Mayor said:
May 6 2019 dropped off my 2019 Denali for rear windshield leak. They tried to pull and reseal, still leaked.
Ordered new rear windshield and it came in Friday May 10th.
Glassman supposed to install Monday afternoon May 12th.  It's Wednesday afternoon and truck still isnt ready.
Hoping for some good news tomorrow.
It's been 16 days without my truck!??
Hope it's resolved for you. I waited 16 days total and mine got the whole window replaced and that fixed it.
I hope so too.  This is unbelievable!
That's exactly how bad mine was. I had both sides too.
It's been 16 days without my truck![emoji58][emoji58]
Do you happen to know your build date?
Sent from my ONEPLUS A6003 using Tapatalk
09-2018
Bingo.
For those readers new to this thread, the rear window leak issue has almost exclusively been on trucks built on or before 10/2018.
So what has been the fix for those who’ve had theirs repaired? I took mine in on Wednesday and they ordered a new silicone recommended by GM per a bulletin that was sent out on this issue. Unfortunately, the new silicone did not correct the issue.
First step is to remove the rear spoiler and apply the sealant/caulk. Second step, I believe, is a complete new rear window unit.
Sent from my Pixel XL using Tapatalk
A new rear window is the definitive solution.
Those windows are straight up defective and should be replaced. Adding extra sealant to a defective window is treating the symptom, not the cause IMHO. Unfortunately your dealer is likely to follow GM's TSB so just sit back, play the game and drive the loaner like you stole it.
But hey, what do I know...only took them three tries to fix mine...the third time being with a new window.
Picked mine up Tuesday. 3rd time was the charm. It’s rained a little here and there since I picked it up and it looks like the issue has been resolved. 26 days total in the shop. GM is also paying my care note for one month.
Supposedly there is a May 30th update to bulletin 18-NA-383 for the rear window leak repair. Does anyone have access to it to see what changed from previous versions?
If only this were as easy as wishing GM would replace the known defective A/C Condensers and Vacuum Pumps on our earlier K2's.
They would rather have two or 3 techs spend a day or more with tubes of silicone to repair rather than install a new rear window.
That is why I am curious what the new tsb says. Maybe they changed it to say replace window.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
