7 minutes ago, eppieguy said:
I run mine through the automatic car was at minimum of 2 times a week and up to 4 times a week and have never seen any water up until 2 weeks ago.
A little off topic, but is this a touchless auto wash you're using?
I've read in another thread that someone with T1 Silverado had the front air curtain ripped off at an auto-wash. (It was not touchless).
Nope, not a touchless car wash, I see no paint issues with my Cajun Red and I've had no damage done. I did the same with my 17 Audi Q7 with super dark blue paint and my 12 Lexus GX 460 and have yet to have damage done to the vehicle and the paint holds up quite well. Since my vehicles rarely get very dirty I think my paint doesn't get the scratches and swirls because there is so little dirt on the paint to begin with. Just my theory but it's been working for me.
12 minutes ago, UGADawgs said:
yeah @econometrics that was me. No more automatic car washes for this truck.
Thanks for chiming in. I couldn't remember who posted that. I'm erring on the side of caution here and manually washing mine for the foreseeable future. Plus, it's a good workout with the size of the T1. LOL
Edited by econometrics
So I dropped my truck off for round two of the rear window leak..
Who else is embarrassed that you get a nice new truck and you have to explain to people when they see you driving another truck (loaner) that your brand new trucks rear window leaks!
Ehh, I'm not embarrassed. Maybe when they gave me an Equinox loaner because it was a piece of shit. But not now that I'm in another T1 truck.
Sent from my Pixel XL using Tapatalk
I wouldn't so much be embarrassed as I would be fliching at all the cutting faces my wife would be making at me for "just having to have that NEW truck NOW"... ?
Trust me when all three neighbors drive F150s and poke fun at you 2 or 3 times a day for 23 days it gets old real quick.
Sent from my Pixel 2 using Tapatalk
Ha! That’s rough.
Not as rough as owning something as boring as an F-150, though... ?
Make sure you print that TSB out and bring it with you. And make sure they test it with a hose real good after 24 hours to make sure no leaks before you bring it home. Strange that you had that many miles and it just started leaking now?
I appreciate the advice. I live in Texas near Dallas. We don't have harsh winters so maybe the extreme cold where other owner's live caused the cracks sooner? I had been checking frequently hoping i was a lucky early build. I'm just glad i was able to catch it before i had to worry about the headliner and mildew.
Sent from my SM-G892A using Tapatalk
So the dealer called me today and advised they are going to go ahead and just replace the back window instead of trying to reseal it a second time. I guess I was convincing enough on the phone to get them to do that instead of resealing it. Said it will probably take a week or so to get the window.
Let’s hope they got it this time. Did they clean  the  rest of the truck and get it looking good?
Picked up mine after the window seal, rained last night, didn't see anything this morning before I left for work. It's supposed to rain pretty hard this afternoon / evening, I'll check a few times tonight and tomorrow morning to see what it looks like. If I don't see anything tomorrow morning I'll run the hose down it and see what happens then. The only thing here is it was a very small leak to begin with, nothing like others have posed with wet headliners and water on the seat, I barely had a drip on the inside glass.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
