3 hours ago, econometrics said:
This list could be updated with a LOT of new entries now...
Would be great if someone could update that sheet with build month/year, purchase month/year, and leak noticed month/year, followed by all work done. My guess is that list would easily be double number of people if not more on that list, not to mention not everyone comes to this forum and many people probably have no idea this is happening, which means this is going to be a HUGE problem for GM.
I tried to list everything in this thread in the below document
Edited by Rocz3cqg
Sliding Glass or / and Stop Light Module reported Leaking Situation
Contacts
    Chevy Customer Care
       https://www.chevrolet.com/contact/email-us
        Chat https://www.chevrolet.com/contact/chat
        Twitter @chevycustcare
        Phone 1 800 222 1020
    Executive VP and President of the Americas
        Barry Engle [Replaced Alan Batey] Email:[email protected]
    Global Manufacturing GM
         Gerald Johnson
General Info and Correction Procedure [GM Bulletin 18-NA-383]
        Window Part Number 84569182 [As of 1/3/2020 it appears GM has like 3 part numbers for the replacement windows]
        Leaks are occurring with Trucks from Ft. Wayne USA and Mexico
        Majority of Trucks are 2019, but there are some model year 2020
        No Solid Windows have been reported.
        Cracks have been seen on the plastic frame of the rear Sliding Window indicating a manufacturing
                               defect or indication that the Cab flexes and is causing the damage to the window casing.
Leaking can be from the Stop Light Module and / or the Sliding Glass Assembly
        This Bulletin applies to Vehicles built before Oct 13 2018. We do have a user reports of Damage
                               with a Build Dates after this.
        Contact the Dealership
       If the Headliner was damaged due to water, the front windshield must be removed for headliner re-installation
                 Allows the Headliner to be inserted thru the windshield for installation
       If the window must be removed, the rear seats will be removed for the process.
        Inspect seating and carpet for dampness and mold and have them replaced. Seats might be a stretch.
        Inspect the paint around the window to insure it is not damaged or chipped
        Inspect Trim in the back around the window to ensure no damage
        Take pics of the outside and inside for future reference and compare to the "after the work"
        So the Dealership will attempt the following  3 procedures.
            Contact Chevy Customer Care and lodge a complaint to get it on the record. Use Chat to keep a record of the convo.
            If need be, send email to a higher up GM Exec which in turn will cause the GM Executive Service Rep to make contact some how.
                   Fish_Guru reached out to the VP at GM and did get a response back. I did the same when I needed a front bumper. So they do
                   followup on complaints. But ensure you follow contacting the Dealership, Chevy Customer Care, state your problem and be
                   COURTESY.
                       1 Pull down Headliner to allow removal of Spoiler. place new sealant on the top edge of the window and check leaks after everything is back together or
                       2 Inspect Window for Sealant crack and clean the old sealant off the window and body and reapply sealant and install window or
                       3 Inspect Window for upper rail cracking and obtain a new window and  reapply sealant and install window
        Try to have all the parts needed on hand and a plan of attack to minimize how many times [once hopefully] they have to perform surgery on the vehicle
Know your Auto Lemon Laws for your State [Example Michigan]
        The law applies to privately owned passenger vehicles and those leased after January 1, 2000, used for personal, family or household purposes.
        Some business-type vehicles may also be covered. The law does not apply to larger trucks, motor homes, motorcycles, or off-road vehicles.
        A defective vehicle is one in which the same problem has not been repaired after four attempts, or a vehicle that is out of service 30 days or more for repairs.
        The first report of the defect must be made within one year from the date of delivery to the original purchaser or lessee or during the term of the
        manufacturer's warranty, whichever period is shorter.
        If the vehicle you purchase is defective, you may be entitled under state law to replacement of it or a refund of the cost of the lease.
        To obtain replacement or refund, you must first report the defect in writing to the manufacturer and you may be required to first arbitrate the dispute.
        In order to protect your rights under Michigan's Lemon Law, follow these steps:
               Keep copies of all correspondence to and from the manufacturer and the dealer.
               Keep copies of all work orders for repairs on the vehicle, including the date(s) the work was performed and the mileage on the vehicle at the time of the repair(s).
               Follow all requirements of the warranty, including any requirement that the repairs must be done by an authorized dealer specified by the manufacturer.
Members                  Vehicle Type    Month/Year Reported   Problem / Results                                                            Build Year
    Kyleb                   Denali             2/19
    Fish_guru            HC                 12/18      Window resealed, Spoiler sealant applied, Window replaced
    SLC                      TB
    JKD                      Denali           11/18      Window resealed, Window replaced
    TommyboyATL  Denali           12/18
    MTSound           TB                  12/18      Window replaced
    HotRdLy                                    12/18      Inspecting a vehicle at a Dealership
    RPH                     HC                 12/18      Window replaced
    O Town Denali   Denali           1/19
    Dzen                   AT4                2/19
    The Silverado    Silverado      3/19        New Window and Headliner
    Anthony2558    TB                  3/19        Glass Shattered, Window replaced
    Smoked             TB                  3/19         Window sealed but not fixed, Going for round 2
    Steve841
    rocz3cqg            HC                 3/19        Window Caulked
    White94rx          LT                   3/19        Window Caulked
    ShamrockShooter TB             3/19        New TB 2020 which leaked also
    Luke Litten
    Corey Helgemo                         4/19       Headliner Damaged
    Miguel Antonio Quioc             3/19        Headliner Damaged        1/19
    Connor Lee        TB                  4/19
    Jeremy Balok    RST                4/19
    George Litourneau
    Scott Daniel
    Richard Fuentes Denali
    M3Master         LTZ                  4/19        Sealed but still leaked, Window replaced
    Eppieguy           HC                   4/19
    Ktapper             TB                    4/19        Replaced the Window
    RedhotRST       RST                 3/19
    Bowtie2007      Denali             4/19
    Chris Arruda
    Daniel Glauser
    KevinTM             LT                   4/19
    JosephWS2019 LT Z71          5/19
    OneTruck60Mexicans            5/19        Cracks in Window Frame
    AT4Rotation                             5/19
   Mayor                  19 Denali       5/19        New Window        9/18
  GSmith308           19 RST          6/19
  dho238                 19 RST          7/19
  Fieldsend             19 RST          7/19        New Window        9/18
  Lebag335             19 TB            8/19        Resealed twice
  RaysB4U               HC                 8/19        Realed        8/18
  WWIII                    LTZ                 8/19       New Window        8/18
  Logan Parr           19 Chevy      8/19
  OntheReel            LTZ                 8/19        10/18
  GHBehnam          Denali            8/19        Sealed Twice
  Trosen                  LTZ                 9/19
 Kozzy                     RST                9/19       New Window        11/18
  Radchad              19 TB              9/19       New Window        2/19
  Frank Devoe        LTZ                 10/19        2/19
  Dale Harris          HC or LTZ      10/19     Sealed Twice
  MattsSVTCobra  AT4                10/19
 Centrebaseball    Sierra             10/19      New Headliner 12/18
 GMDog2               Denali             10/19
  Dvhounddog       Sierra Slt        10/19     Sealed and new Headliner
  Chris Callanan    Sierra Slt        11/19
  Tony Johnson     RST                11/19
  JohnCasey                                  11/19     Sealed twice        1/19
  Econometrics      RST               11/19        2/19
  McCoy7                TB                  11/19        5/19
  Samdsjr                LT                  11/19       Sealed three Times?        3/19
  Wiggums              RST               12/19
  nhuntsman           AT4               12/19      New Window        2/19
  Marcus Dean       2020 LTZ 2500  12/19  Resealed
  F8lvnm                  Denali          12/19
  Ptownvdub                                12/19      New Window        10/18
  AKHighCo8untry  HC               12/19        8/18
  Jamie73                Sierra          12/19
  UGADawgs                                12/19        11/18
  ShamrockShooter 2020 TB    12/19       New Vehicle via Buyback leaked [Window getting replaced-frame cracked]          8/19
  Brileavi                  Denali          12/19
  DeanSterling                              12/19       New Window
  Smit303                Denali           12/19
  WarHawk89         TB                 12/19
  Hiranger                LT                 12/19
  Hiranger               Z71               12/19       Loaner
  Hamilton2400     RST               12/19      New Window
  CarLosh                                      12/19        2/19
  Deewc74                                    12/19
  Porterhouse        RST               12/19
  Alan Bates           20 2500        1/20
  Ajayen                  19 LT              1/20
  Psufan                  19 Silverado 1/20
  Kenneth Ezzell                            1/20        7/19
  Hueless                TB                   1/20        3/19 Mexico
  Setex                     Denali             1/20        7/19 Ft Wayne
  Billet Bowtie         HC                   1/20        10/18
  William Lee Wahl  LTZ                                  Window Replaced        8/19 FW
  Justin McAuley        7/19 FW
  Andrew Martinez        10/18 FW
  Sawyer Thompson 2020 2500
  Lion3663               Sierra              1/20
  Tinbad                   TB                     1/20        5/19 Mexico
  GMC AT4 4 Leak 2019 AT4         1/20
  Garry McClanahan LTZ                 1/20
  Dad                        2020 AT4         1/20
  Jgisonfire             HC                     1/20        5/19
  Chad Hynes         Denali                1/20
  OhioSpartan        Denali                1/20        7/19
  Randy Brumfield                            1/20       Window Replaced
  Anthony Duong  AT4                     1/20       Window Replaced
  DaveHC               2020 Denali       1/20       Window Resealed
  Dzen                    AT4                      12/19    Window replaced in 1/19, leaked again 12/19, Replaced window
  Marco Hernandez from Facebook
  Dory W. Covington from Facebook
  Jason Tropea from Facebook
  Ryan Norstom from Facebook
  William Lee Wahl from Facebook
  Samuel Scruggs Jr from Facebook [Also his Rental]
  Michael Pruitt from Facebook
  Joe Hoernke from Facebook
  Kris Neill from Facebook
  Jeffrey Schmucker from Facebook
  Dan Allen from Facebook
  Ian Christopher from Facebook
  Kyle Forbes from Facebook
  Carlos Hathcock from Facebook
  Stephen Weiss from Facebook
  Stacy Sharp from Facebook
  Tony Sims from Facebook
  Ryan Smith from Facebook
  Mike Decosta from Facebook
  Randy Anderson from Facebook
  Refugio Alvarez from Facebook
  James Bennett from Facebook
  Michael Bryant from Facebook
  William Crane from Facebook
  Jakob Kindt from Facebook
  Michael Roescher from Facebook
  Jesse Lizel from Facebook
  Bill Jones from Facebook
  Branden Grant from Facebook
  Todd Stewart from Facebook
Some of the users from Facebook may have an User Id on the GM-Truck Forum [therefore duplication may exist] Total Count is 133 as of 1/12/2020
I am sure there are many more that were not caught or seen on Facebook because I did not go to far back. [Just browsed for Leaks]
The TSB 383 has been updated to include 2019 and 2020 1500 Silverado and Sierra and 2020 2500 and 3500.
Edited by Rocz3cqg
  • Thanks 4
Wish I could give you a strong high five ?? in person. Thank you!
nice work! was thinking maybe a google doc could be easier? That will allow people to add their name/truck etc to the list with a public link to the doc
Contacts
    Chevy Customer Care
        Email [email protected] or https://www.chevrolet.com/contact/email-us
         Gerald Johnson
                   COURTESY.
    Kyleb                       Denali          2/19
    SLC                            TB
    Dzen                          AT4              2/19
    Steve841
    Luke Litten
    Miguel Antonio Quioc           3/19         Headliner Damaged        1/2019
    Connor Lee            TB                 4/19
    George Litourneau
    Scott Daniel
    Eppieguy                  HC               4/19
    RedhotRST              RST              3/19
    Chris Arruda
    Daniel Glauser
    KevinTM                  LT                4/19
    AT4Rotation                               5/19
  dho238                      19 RST          7/19
  Trosen                     LTZ                  9/19
 GMDog2                 Denali            10/19
  Wiggums               RST               12/19
  F8lvnm                  Denali          12/19
  ShamrockShooter 2020 TB 12/19  New Vehicle via Buyback leaked        8/19
  WarHawk89          TB                 12/19
  Hiranger                 LT                  12/19
  Hamilton2400                           12/19
  CarLosh                                       12/19        2/19
  Deewc74                                    12/19
Nicely done! Wow
Probably a good idea.
So my service rep texted me that they finally got my 2020 trail boss in and removed the spoiler. He said the window frame is indeed cracked it's not just a bad gasket as I had speculated. Given how much water I soaked that truck with when I first bought it in October to 8 weeks later when a light mist from the hose caused active drips inside tells me it's a body flexing issue causing the plastic to crack after it leaves the lot. From my 19 that had a new window installed, I have seen the old window and the new window style. I know for sure my 2020 has the new window design.
My regional service manager had already said he would approve a new window and skip the caulking step. But I am starting to doubt if a new window will last 2 months before cracking. I have a steep driveway, probably 3 to 4 degrees and truck really flexes every day pulling in and out at a 90 degree turn from the street.
Has anyone that has had their window replaced developed a second leak?
My service manager was going to talk to the regional manager to see if he could get input from GM about what to do. I'm guessing they will throw another window in and if that one gets cracks in 2 months then they have a serious design flaw on their hands to figure out.
Sent from my Pixel 4 using Tapatalk
You had a leaking 2019 and now a leaky 2020?
Sounds like at least they are actively trying to make it right, which is good.
but you have a freaking trail boss - a 3 to 4 degree driveway really shouldn’t be a problem...or else you are exactly right , that GM has a huge problem on their hands.
I can’t remember if anyone’s replacement window has leaked again.  I can’t think of anyone off the top of my head though.
Yes. I know there are bigger problems in the world, but $120,000 worth of leaking Trail bosses in 6 months really sucks.
Also my driveway is steep enough that I have to park it in 4wd or it will slide down the hill and end up in the street during the winter.
Add me to the group as I have a leak in my rear window (2019 Silverado)on the driver's side as well.  Not a big leak, but a leak nonetheless.  Very frustrating.  I called the dealer but still waiting for a call back.  This is my THIRD new Chevy truck in the past 12 months as my other 2 were bought back by the dealer due to transmission issues (2018 Colorado) and a collapsed dashboard (2018 Silverado).  I guess bad luck really does happen in threes!
  • Sad 1
    jack-arrrdor
    jack-arrrdor
  • Who's Online   2 Members, 0 Anonymous, 1,621 Guests (See full list)
