24 minutes ago, Porterhouse said:
What's the electrical boxes under the window power?
One of them might be the Video Processor Module. The other could be the Onstar Module.
19 minutes ago, magnum74 said:
I got hooked on reading through this entire thread and the fact that the problem has carried over into some 2020's makes me thing twice about dropping money on one of these new gen trucks in a year or two. No matter how much they test this stuff still happens. Leaky window is never acceptable no matter the price point of a vehicle.
If I would have known about the windows leaking I would have thought twice. Every time I go to my truck after it rains thats the first thing I check.
In the pic, the silver finned one is the Bose amp. The one next to it is the power inverter for the 110v outlets. My truck also has what I believe to be the video processor for 360 cameras, down on the pass side below the sliding window motor. It doesn't look to be equipped on the truck in the pic. There is also a small module down on the driver’s side which if I recall is the park sensor module. Depending on the options your truck has, you may have all or none of these modules to even worry about.
Nevertheless, all of the modules looked to be potted / sealed except for the inverter which presumably has to be open for heat dissipation. There is also a piece of foam between the seat and these modules which may divert some water.
Edited by OnTheReel
45 minutes ago, ShamrockShooter said:
So apparently my new window is in already. So I have the option to install the seam sealer fix over top of the new window before they put the spoiler on as a "double" line of defense. Thoughts?
I think I'm leaning towards just the window as I would want to know if the frame cracks right away again. Versus having it crack and be covered by sealer only to leak again in a year when the sealer fails.
Sent from my Pixel 4 using Tapatalk
Tough call. Unfortunately based on the info here, I really feel like it’s only a matter of time until the replacement window cracks. I’d be inclined to want to see it as soon as it does.
But then you do wonder if the sealer is applied over the top right away, would the window ever crack in the first place? Or would the sealer give it enough “reinforcement” to prevent it? Probably not. Just thinking out loud.
Well it very well could be a factory installation issue compounding the cracks in the frame. If I get a really experienced glass installer which is what my service advisor requested from the glass company, a fine install job in the new window may be the difference in it never cracking.
Only time will tell. Like when I load up my truck up to the gills, hook up my 4,000 lb travel trailer and back it in and out of my steep driveway on a 45 degree angle. You want to talk about body flex and stress. If that doesn't crack the frame I should be good to go.
41 minutes ago, Centrebaseball said:
2019 sales numbers are out - 807,xxx trucks sold in 2019.  Wonder how many have leaks?  1%? 5%? 25%?
The real question is what % have leaked so far, how many will leak in 2020, how many will leak before warranty expires, and how many after the warranty. Can you imagine these sitting on lots as used vehicles in 3-5 years... I am surprised Consumer Reports, Edmunds, TFL, KBB, or any other publication hasn't reported on this, yet.
That’s my exact plan.  Use it up until the warranty runs out and then get myself a new body tundra.  Or hell, maybe I’ll go nuts and get a Cybertruck
I got my truck back on Friday, 1/3. It does indeed have a new rear window. However, I verified that the glass was manufactured by the first GM supplier and not the new supplier. At least it doesn't leak.
how were you able to verify this? By part number? My new window is sitting with my truck in the shop ready to be installed Thursday so I would love to know which it is.  I’ve been assured it’s the new design / new supplier window.
I took pictures and videos of the truck before I dropped it off. I also received a 2020 Silverado loaner. Between the pictures and the loaner, I was able to verify the two different glass suppliers on the actual glass. The 2020 had the new supplier glass whereas my 2019 still has the same supplier glass before and after the replacement.
1. Anyone know when they switched suppliers and how can you verify which window is in your truck. I have a 2020 build date 9/19 so I’m guessing I could have either?
Just a heads up, my 2020 denali built in usa is leaking from the front I think, had radio off the other day and heard water flowing as I stopped, and again once I started off, being my truck had all weather mats I never knew till I raised them up I had soaked front carpet both sides and even the rears were damp. At dealer now, a water intrusion specialist (their words) is coming tomorrow to check out and hopefully fix it. never washed yet a little over 1k miles and 6 weeks old. we have had severe rain several times. fyi.... I read gm does not water test every truck, they only do a random selection and test from the assembly line.
Edited by DaveHC
Delete.
Edited by SeTex
FUYAO is what is on my Oct. 2018 Fort Wayne built Silverado. I can't remember or find the picture of the name on the 2020 loaner that I had.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 870 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
