1 hour ago, TrailBossLemonEdition said:
Well I picked my truck up for the last and final repair to get things right. I got the most updated window (FUYAO E4 43R-000072) It water tested and everything was water tight so far. They still had shitty looking sealant around the window, but not as bad as the hack job they did before.
Does your frame above the slider look like the picture I posted earlier today? Straight up?
56 minutes ago, Chip said:
My window is shown below. My Denali was built 8/19 and I took delivery a year ago this month. Window began leaking a month ago on drivers side. Took it in last week and the Dealer is waiting for bolts etc. to show up.
I think we're all misusing the part numbers. I think that's the glass number, not the entire assembly number. I may be wrong though.
1 hour ago, cltsig said:
Is that THE window which does not leak?  I sure as hell hope so. I just checked my 2020 AT4 built in July 2020 and that’s what it has.
Supposedly but I think there’s been some in here that leak.
Yes it’s the same one posted earlier.
Yah - I have that E4 glass and it leaks. The incompetence is laughable.
I have 2020 GMC 3500hd Denali Ultimate with the Duramax. At 300 miles I noticed a small stream of water coming down the rear window on the drivers side. The dealership removed the spoiler and observed the hairline cracking in plastic. They applied the seam sealer per the bulletin.  A week or so later in a heavy rain the drip was still there in the same spot. The dealer than installed a new window. This new window now leaks on the passenger side worse than before. They state this window also has hairline cracks in the plastic and they need to order another new one. I am not too optimistic as my truck was built in June of this year and the replacement window was just installed. Sounds like the same flawed design will be installed another time. Really disappointed in GM and the quality in a 80k truck.
I’m hoping for a class action lawsuit at this point. TSB isn’t doing it. Can’t believe I’m dealing with this on a brand new truck too. I’d have someone else make these windows, clearly Fuyao is garbage. Which comes at little surprise.
Sorry you've had this crappy experience, like the rest of us have.
I've just learned to live with my leaking rear. I took it in the first time, had the sealant applied, and it seemed to slow the occurrence of the leaks. After reading stories just like yours - where owners keep bringing their trucks in over and over for more "fixes", I just decided to put a towel between my rear window and my seat, forget about leak and move on. I can honestly say I barely think about it anymore, and I enjoy the truck again. The best part has been staying away from days/weeks messing with this at my dealer - with no end in sight.
Probably not the best, but I've moved into the "acceptance" stage of grief. ?
I have always suspected something like that. I even told the dealer that since I purchased the truck I hear clicks, clunks, and thuds coming from the top rear of the cab. It happens when the truck sits hot in the sun all day and starts the noises on my ride home as the cabin cools down. Sounds like something expanding and contracting as the inside temp changes. Even my kids in the back are like what's that sound.
I had mine serviced last week they filled it with the sealant and since we’ve been getting rain here in Texas the last few days I’ve been looking it over real good and it’s not leaking but it’s only been a week. Since  it’s been serviced now I see 2 good size cracks in the plastic window frame needless to say I will be calling the dealership to get another appointment there gonna have to replace the window I didn’t spend the kind of money to have a cracked rear window also I see lots or rust on the window as well.
Kind of have to zoom in to see it. Idk why the camera has a hard time catching it looking at the window it’s plain as day.
It sucks but I think the best remedy is to ask for a solid rear window. I’ll probably do that when mine eventually leaks.
I’m thinking about asking for a solid the slider is pretty useless too me. I’ll never open it. The sealant seems to have stopped my leaking but was just done last week. But I can’t accept knowing there’s cracks in the frame just waiting to crack through and leak.
    TopBo
    TopBo
  • Who's Online   1 Member, 0 Anonymous, 1,028 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
