Any updates on what these plugs look like? Would love to see some pics. I'm probably going to take the front OEM flaps off my trailboss and put on larger standard style mud flaps (not molded)
Is there a plastic trim piece I could get from the dealer that would cover the hole behind the front mud flap?
Anyone have a US source for the plugs? I don't care if they're not painted
Edited by Donnyb313
Goodness, when I first saw the picture, I was absolutely mortified at the unpainted steel then realized it was the reflection and you were referring to the holes.
Here you go!  From the US:  https://www.sharptruck.com/gatorback-color-match-summit-white-replacement-plugs-10-pack
  • Thanks 1
  • 9 months later...
I just got my 2020 Silverado. I'm also looking to remove the mud flaps and install the plugs. I assume that I will need four (4) plugs?
Thanks.
Thanks.
Yes.  Follow my link posted right above.  They work perfectly.
OEMs are stone guards not mud flaps. If you remove them and do not replace with mud flaps, you'll soon find out why they are called stone guards; and, the damaged caused to the paint by kicked up stones will take your mind off the hole.
I can see using the plug for the exposed hole if also adding flat rubber flaps, but the wrap around molded ones make adding a plug unnecessary, provides added firmness and prevents water and abrasive road grit from getting behind the flap where it can sit and with flap movement being blasted with rocks, stones, ice chunks eventually grind away the paint and rust out the area underneath.
  • 3 months later...
On 5/3/2020 at 8:12 AM, 2019Custom said:
Thank you for this. Anything special with installation or is it simply a push plug?
Just a push plug.  Super easy.
  • 10 months later...
sorry to resurrect a dead thread. just got a 21 silverado.  how did these plugs hold up long term?  i see the sharp truck ones say they don't work on the back, and another thread said they were too short for the back.  Wondering if they fell out over time or anything wonky.   thanks!
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
