The best lift for my Silverado
Pepe1
1 hour ago, jimmyboy8301 said:
Angles with bilsteins set at 1.25”
I’ve had 7 lifted trucks. 3 BDS, 2 Superlift, 2 Zone and the BDS and Zone were excellent lifts giving me 0 issues. I’m far from a newbie in the lift or truck world . You run CST year round and the finish will eventually corrode like any other lift will, then you’ll really freak
What kit and size wheels did you use for this truck?
  • Replies 54
Zone 4.5” with bilsteins set at 1.25” and I’m running 22x10 forces on 33” nittos
25 minutes ago, Pepe1 said:
Nice truck man. Did you upgrade the upper control arms and any other mods besides the lift?
Thanks - Did not modify the upper control arms - didn't need to.  Only thing I did was upgrade to Fox shocks in the rear.  People always get in my truck thinking it will ride rough and always end up amazed that it doesn't.  Its really a factory like ride if not better.  Oh and I've had it on there for approx. 40,000 miles and no "lift caused" repairs of any kind.
Thanks man defiantly made up my mind. There’s a lot of kits out there but I’m going to give zone a try. I will be sharing pictures and reviews of my outcome. Thanks again
I'm also running zone 4.5, bilstein up front and Fox 2.0 in the rear. Exact same setup as jimmyboy8301. I'm running stock wheels though.
Well, my bilstein are at stock height in front, so no extra lift there.
Ihave a 16. With mcg lift. 33 on 22x12 -44 offset (its the wifes, i hate lifted trucks) anyways. I didnt cut anything and the barely clear having a 7" lift in front.  So you may want to rethink that offset and width
6 hours ago, TXGREEK said:
Even though you’re now pretty much stuck with it but you’re saying that you’re ok with cutting up your trucks cross members, cutting up your differential, widening your track and turning radius, causing much more stress, adding controversial spacers, not being able to use stock wheels and tires and much more?
Are you trying to say you didn't have to cut your crossmember to install your CST kit? If you are,  your totally wrong. Maybe you better ask your mechanic how he got your lowered  front diff to clear that crossmember without whacking off a chunk of it. CST like all sub frame drop kits require cutting the crossmember.
Hell you say lol
CST doesn’t cut into the frame at all, just a small cut on a trim pc to clear the steering extension. I didn’t mean to make your choice of lift manufacturers seem as underachievers that not only destroy your frames and give you wide clown tracks but please, give it up, I even lied and complimented your truck and your still going on, wow!
Let’s please stick to the OP
I have a 7” RC lift and have had no issues at all. It was on the truck when I bought it so didn’t have a choice. It’s clear this is a CST sales thread so I’ll move along
 I know OP aont gonna fit a 22x12 -44 on anything under a 6 without cutting.
Id choose cst over all those liftsas well. I like cst pruducts. Used a lot of their stuff
1 hour ago, Nasty said:
 I know OP aont gonna fit a 22x12 -44 on anything under a 6 without cutting but i just dont like the fact you bring money into it.
He WILL clear that setup with without cutting if he runs adjustable front shocks.
Corey’s truck (on the right) is a CST 4.5” on 33” Toyo AT2s and 22x12 Welds. No cutting, no trimming. Front resi’s turned up slightly.
If you want to see a truck that has it all, take a look at the one behind mine.
CST 4.5 with front resi coil overs, rear resis
Weld wheels (billet), a blower, and a few other odds n ends
Stay on topic. No need for personal attacks on each other. Several members are on thin ice. You can IGNORE another member if you wish. In fact if you hover over another poster's name, you'll notice an option to "Ignore User". I would suggest a few of you choose that option since you can't seem to play nice
Just looked up the cst installation instructions. Requires trimming of the lower control arm pocket, and all of the UCA mounting points.
Instructions also include removal of a bracket from the front crossmember, as well as drilling several holes in it.
This all looks very similar to many other types of lifts I looked at when I was making my decision.
Not trying to instigate anything, but I think saying that cst is easily reversible is not quite true. While there is no differential modification, you are certainly modifying enough that simply taking off the lift would be no small task.
OP: there are a great many people running all of these lifts with great success. CST, BDS and Zone all make a great product, but each has pros and cons.
    • What meaningful corrections were done to fix the "machining errors?"   I bet nothing, because the 6.2 is soon to be obsolete. Why would GM implement any fix let alone an "expensive one?"   Until someone can provide any convincing information that GM did ANYTHING to correct the engines - the 6.2 is no for me.    Which means keeping the 2016 Denali longer until the next generation (6.6?) proves itself.
    • If my father took a Sunday off. We did the Sunday drive. Usually stopping at a Geno’s for dinner that we eat in the car. Six of us with my little sister up front. It was always a Buick growing up. In New Jersey you couldn’t get lost. Not like Texas.
    • Hoooooooly smokes, batman!
    • I suppose I am Atlas. It can always be worse, eh?   I had a friend once that rolled one payment into another until he was paying the price of Benz for a 10 year old back marker. Wouldn't be often you start a new payment the month following your old one.
    • I still enjoy the drive   Some people fish when they retire; some golf. I drive. We've lived in the same general area now for twenty eight years and I'm still finding at least monthly some sweet quite little road to explore. When I tell the Mrs. I'm heading out for coffee she knows that could be a five hour event. Often she even goes along.    I like finding new rural routes used mainly by the locals that start nowhere in particular and end the same way. Many in the area of that type are narrow paved and twisty, hilly and run through field and timber. Often along creeks or wetlands. Unfarmable areas of great natural beauty.    After years of this type of exploration they start to fit together. One ending a mile or so from another and you start threading together a new path from a unfamiliar place to a new adventure. Sometimes to a little town of under five hundred that used to be something before the Interstate or some railroad or US highway bled the life out of it that has a small dinner with the greatest slice of pie you've eaten since grandma made her last. A little village museum or library or even a town square park with grand old oak, walnut and Osage orange trees to sit under while you sip you gas station coffee and chat up some locals.    Often they are full of stories about the main streets more interesting buildings and the who's who of the area. Sometimes some hidden attraction or unseen history. Our area is full of old coal mines.     A younger self used to do this going cross country by motorcycle. Only a general area as a destination with no time to get there and no time to be back. Sitting at days end in a 10 unit off the main highway motel under a Sycamore tree yacking with the owner or his one semipermanent guest while I adjusted valves or the chain. Always a wave and a shout "Hey there stranger"!  It's how I came by my love of old Brit iron. There is no such things as a ten minute gas stop when your on a Enfield or a vintage Triumph. Same being true of old cars.    If you take the time to really look I've found everywhere is someplace interesting. Illinois or West Virginia. Different and yet the same.    People are in a more relaxed mood and will talk about anything and everything and if they like you there may be a cupp'a or a lemonade and a sandwich in it. 😉
