1 hour ago, Bgctrading said:
My 16 high country has telescoping steering wheel.its a separate lever behind the turn signal.
The base three trims do not telescope anymore. Sad to say I think I’m writing GM off my list of trucks to look at this spring. They’re missing too many things I can get on a Ford, Ram or even the Nissan.
  • 1 year later...
Got a  2019, so dam basic, always been a Chevy man, but this might just be my last one, hate to say it but unless you're getting the 2500, the other trucks are far more superior. Why would you take Sirius radio out, and who puts none powered seats in vehicles in this day and time, not to mention the rubbing noise that the manufacturer telling you is normal, (ughhh why my last truck didn't do it if it's normal) this thing should cost about $18,000. Literally, all you get is an upgraded radio, and that's only if you get the trim with the Sirius radio.Never have I purchased a vehicle and hated it after only a month!
No lighted visor's?‍♂️ that would be added in the new Yugo if there was one!
Edited by Unhappy Chevy
Are you talking about the little concave in corner of drive side mirror?
I was referring to electronic blind spot monitor like in my previous Malibu Premier. Would alert me with a tint orange icon if someone was next to me.
Which does your RST have?
My rst has blind spot, the orange icon
Sent from my SM-G973U using Tapatalk
You have to get the safety package to get that. I bought a Trail Boss, had to drive 100 miles to a different city to get one that had that. It doesn't have the full High Country features, but the TB safety package has blind spot mirrors, collision alert, and the cross traffic rear warning.
All things you lose with towing mirrors. My Trail Boss has the towing mirrors from the factory.
Did you even look at the damn truck before you bought it? You can get manual seats and no satellite radio in a 300A XLT Ford or a basic Big Horn Ram. If you want those features you have to opt for a specific package, no different than GM.
  • 5 months later...
So did anyone have any luck w/ the lighted sun visor swap on a TB?  Have a 2020 TB & am looking to install the lighted visors ..., took the stock visor on the driver’s side off today to see if I could find the wire, but no luck. I’m thinking it’s gotta be there, just like the wire was there for the auto dimming rear view mirror. Thanks gentlemen.
I know that GM installs certain options as only part of packages to standardize and reduce “their” cost. Back in 1980 I ordered a K10 Silverado (Silverado was a trim level back then, like LTZ) and you could order almost any option by itself. I was able to get power windows without power locks. 4 speed manual too. Now if you order certain options you have to get a package or some packages are not available with certain options. The only thing I couldn’t get when I ordered the available tachometer was a clock. The tach replaced the fuel gauge which was moved to the clock location. Pre-LED display in the radio so the clock was analog in the display console.
Parents had an 81 K5 Blazer (Silverado trim).  I remember this option.  You either got a HUGE fuel gauge or tach.  I miss being able to order ala carte.  I would have added a few things to my LT Trailboss like HUD and A/C seats
Exactly! Or, GM could've made Trail Boss an option package instead of a trim. I would've bought a LTZ Trail Boss with the brown leather interior the LTZ has.
On 1/16/2019 at 9:29 AM, Sierra Dan said:
I didn't think so. No locking gas door on any GM truck I can ever recall.
Speaking of this, what is the reason for eliminating the fuel cap? No way the spring loaded flapper can seal out foreign materials as well as a screw on cap.
I will agree. I wanted an LTZ, but even though I am in my early 60’s, I like the look of a “low” lifted truck (My wife, all 5’-4” of her, drives a Wangler Rubicon with the factory 2” lift). I didn’t want the hassle of doing an aftermarket lift.
Since the Z71 is supposed to be the off road package, I don’t understand why they just didn’t add the lift, shocks, tires, etc. to the Z71 package. Or at least a Z71 “+” package similar to the Z71 appearance package.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
