2017 6.0 Intake part identification, For the love of God
EZTundra77
I have been trying to figure out what the knobby round thing is on the very top front of the engine in my '17 3500 HD 6.0.  It seems attached to the air intake.  My guess would be that it's a resonator or something.  I know that I'm not using proper terms here.  But I gotta know.  My '16 Sequoia had some sort of resonator on the intake and when I upgraded the CAI on that with the TRD kit, it made it sound a little louder and a lot better IMO.   Please help before I go bonkers.
A picture would be nice
That would make sense wouldn't it.  'til the break of dawn!
  • txab changed the title to 2017 6.0 Intake part identification, For the love of God
It's a silencer just like the snake out the bottom to minimize intake noise.  That's all.  The factory air intake has no issue making power to 6000 rpm at least with a lot more aggressive premium fuel tune so unless you want some intake noise I wouldn't worry about it.
Removing the silencer from my Sequoia made the engine sound meaner.  I wouldnt mind that.  Im not looking for a hiss or whistle or anything.
I realize the stock intake is already a cold air intake. I’m looking at cheap kits that offer a smooth, non ribbed main pipe and a larger filter element. I’m not expecting big gains.  I just wonder what is meant by “intake noise”. The sound difference on my sequoia after I put in the TRD CAI sounded more like an exhaust note. It just made it a little more throaty somehow. I don’t know what is meant by “intake noise”
Intake noise is just that..... noise.  You know, the stuff they are dampening with the silencers.  They don't build these so you hear every burble and fart it makes when you play with the throttle and bring down the overall DB at wide open throttle because the 99.99% of owners leave these trucks and just want it quiet and pleasant.
I am sure you can find some $500 sealed cold air that will give you what you want.  The simple solution would be an Airaid MIT tube but rocking the stock clutch fan you won't find one that fits it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
