Billet Grille 2016-2018 Silverado
  • Replies 43
So you say I should leave them alone?20180604_171338.thumb.jpg.7595edab26692b2443da760953cbd234.jpg
Id get a high country or ltz grill myself (just like i did because the lt grill was to plain)
Sent from my SM-G955U using Tapatalk
Are you looking at an insert, or an overlay?
I'll probably leave the silver truck alone. But the black one needs something different.
Still looking for something besides a LTZ or High Country grille though.
Insert or overlay whatever looks best.
Past experience with both is, overlay never want to fit all that well, and you have to cut your grill to put the inserts in (cleaner look), but you grill is now chopped up. Either way you go, you will still be using your factory grill as the "frame". Have you been able to find the mesh in a black, or black chrome?
Yes they have plenty of those available , but I hate black anything except for the truck itself. Black wheels especially. Yuck.
I had a nice billet overlay on my 2003 Duramax but it had a frame around it . No loose ends that get bent. The overlays I see for these trucks look pretty cheap if you ask me
I'm not afaid to spend a grand or more on a nice looking grille either just no black or black chrome.
T Rex has some good looking stuff .
I'm in no hurry though I'll look around.
BTW guys I'm 56 and I'm old school so I just don't get the black murdered out look never will
I agree with the monochromatic look, but I think contrast between black and chrome is a great look. It would be a LOT of chrome on the front of your truck if you go with any chrome insert. Here is a picture of the 16 I had:
5 hours ago, dieselfan1 said:
Get real . I just found this. I suppose you think it is hideous?
That's terrible.  Like puke in my mouth terrible
Bet you like the stupid light bar though. That's lame  .
Let's see your grille
I think they both look balanced right now chrome wise, well you could add chrome strips on the side window molding.
If you had color matched front ends then I think you could get away with one.
You are probably right . The silver one I'm leaving alone.
I just think the black and chrome  together is pretty cool. I'll look for something that isn't all chrome.
No, it would look better without the light bar but I still wouldn't like it.
My grill is a stock 2018 LT Z71 in Ocean Blue (so painted blue grill). I just swapped the gold bowtie for a black one.
I don't mind the regular LT grill, I just prefer painted over chrome.  I also feel billet looking good ended with the 99 trucks.  The 99-02s look ok with it, put pre 99 looked the best.
1 hour ago, damnthetorpedoes said:
Pretty sure every newer truck that I’ve seen with a billet grill also had stick-on chrome side vents...
Just sayin
Billet is definitely not for me, but if it's something you want you should do it. Your truck to do as you please. Again, just not for me. Neither is the mesh.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
