Hi All,
Looking to do the muffler delete on our 2018 5.3 Crew Cab.   I've read a ton and think this will be the best solution for what I am looking for, just a bit more V8 sound.   Will be keeping the flapper and rear resonator in place, just replacing the muffler with a section of pipe.   I did the rear resonator delete on our last truck, a 2016 5.3, which I liked as well.
I know the muffler inlet/outlet are a bit offset.   My question is, has anyone just used a straight section of 2.75" ID pipe to replace the muffler?    I am thinking that the two sections of stock pipe can get close enough to a straight line once the muffler is removed to allow me to just use a 2.75" ID straight pipe without needing to bend a slight S into it, but wanted to see if anyone that had done this themselves had any experience with this.   I don't have a pipe bender.
Thanks!!
It doesn't.   There's 100 videos of it.   With the cats, flapper and rear resonator in place, it sounds good and is still fairly quiet, looks bone stock.   But thanks anyway for the unsolicited opinion that had nothing to do with what I asked.   Very helpful.  /s
  • Haha 3
2 hours ago, Jacoby said:
Its gonna sound like ass
brilliant statement smh
as for how it will sound, it should sound fine. I have a dynomax bullet dumped right before the axle on a 6.2 and IMO it sounds great. quiet at idle , rumbles nice at acceleration, and screams at WOT.
The modern exhaust system is a series of mufflers. The cats muffle a bit and the last one the resonator is a muffler. It done in a way to be less restricted. So eliminating the muffler will increase sound some but it wouldn’t be like there’s none on there. I did it for awhile it sounded fine. Of course some wouldn’t like it, that’s why there’s different brands of mufflers.
they only way these trucks are obnoxiously loud is with headers
In my younger days I ran headers and glass packs all the way out the back. Car or truck didn’t matter. Did straights on diesels. I always lived in the country, no one close to wake up. In my late 50s I wanted it quieter with the exception of my old truck. It’s like a switch was hit and it became noise.
Yeah I'm going to leave that cat converter alone.   Just looking to lose the main muffler.   If I can do it with a straight pipe I'll do it in the driveway with a section of pipe and a couple good wide band clamps.    If it needs a bend I'll take it to a shop.   Just wanted to know if anyone had used a plain old straight section to replace the muffler or if it had to be bent to match the offset inlet/outlet.
Anyone?
Consider a bypass instead of a straight pipe. Gives you the option of two modes. Just an idea.
I had a guy weld up a whole '70 Camaro exhaust for $200. He had to bend and weld.
Was calling around for 2.75" pipe and found a guy that would cut it, bend it up and weld it in for $90.    Got it done a couple days ago.   Left the flapper and resonator in, just lost the main muffler.
Sounds fantastic.   Very deep but not super loud, just enough to hear the V8.
I also clamped the flapper open, makes it sound better at idle and part throttle.   The v4 mode does get louder with the flapper clamped open, but I'm used to it since this is my 4th vehicle with an AFM/DOD V8.  This truck does mostly around town driving with the occasional long trip so I usually just put it in L5 to keep it out of V4 mode.
Highly recommend this to anyone about to drop coin on an exhaust just for sound.   Guy who did it even said he's got people that come in and spend $900 or more that don't sound that good.   And he already had my money... :D
Ended up using 3" pipe and slipped it over the 2.75, welded the small gap shut.  Left a small weep hole in the bottom weld near the flapper, and it needs it.   Lots of water comes out on startup.   He said the water never makes it over the axle hump and collects there.   We do a lot of short drives so need to let it drain.
Edited by TwoBallScrewBall
  • Like 5
Although I’d like my truck to sound good I’m more concerned with the power increase and mpg increase. Have you noticed a ny from this mod?
On 1/18/2019 at 1:29 PM, TwoBallScrewBall said:
Just got quoted $150 by the local Meineke for a straight pipe installed...   seems very high to me.
That is high.  I paid $50 to have my old worn out Flowmaster cut out and weld in the new Magnaflo I brought with me.   To show how prices changed, back 10 years ago I did the same thing when my first Flowmaster went bad and they only charged me $25.  They know they got you. Stinks but my welding skills suck.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
