So I've watched the YouTube video, did the reset with 1 and 3 held together and tried the normal programming procedure of holding the transmitter (next to it) and button 1 or 2 or 3 etc while pushing both at the same time and it won't take!  It's an old LiftMaster remote but I thought it was supposed to start out slow flash to fast flash on the Home Link button but mine always starts with Fast then eventually goes to Slow but never takes!   So frustrating when it should be an easy task.   Yes the normal remote works fine and opens\closes the garage door like it should.   hahaha
has anyone ran into this or know if there is a compatibility list for garage door openers etc?!  This shouldn't be this tough.
Thanks in advance!
Smitty
Have you tried doing the learn process by pressing the button on the back of the garage door opener first, then pressing a homelink button within 30 seconds?  I had to do that for my 3rd car garage door to get it programmed.  That opener is 15+ years old.  This process worked for both my '19 Silverado and '19 Traverse.
What Phil said, I had to do that process with both Ridgelines and both Pilots that we've had.  I parked them in the garage, one at a time, and did what Phil described.  I'll be doing this, after I get my garage cleaned out, for all three of our vehicles, hopefully, soon.
I had an old lift master to. You had to be within five feet of it to work. Eventually it quit working altogether. Bought an new opener and it programmed fast and works 30 yards from driveway
I have an old,  15yrs maybe Genie and it worked.  I had to use the Genie remote first, then to to the opener and press the learn button on the opener it's self and then it worked.
Don't some of the openers use rolling codes, which complicates the programming process sometimes?
I have a 2020 trail Boss, let me warn anyone who has a Genie garage door opener , follow the specific directions on YouTube or you will never get your opener to work. You have to program your opener to the truck then use the learn feature on your garage door. Spent a hour and a half trying to figure this thing out!
I had the exact problem with an old Liftmaster opener without a learn button. I fought it for awhile and finally put in a new Genie and problem solved.
Now I have 2 Genies and both are programmed with Homelink on my 2020
Silverado.
Oh yeah, I park my truck outside so I rewired my Homelink in the truck so it's on a keyed switch. Don't want some fool breaking in my truck and opening my garage door and going in.
I had to hold the garage door remote inches away from truck opener and go thru that process first then had to go thru the process of the garage door opener, First door went great but had to have my wife in the truck hitting truck button while I was hitting the learn button on garage door opener and it finally took after bout eight try's .. Good luck..
Edited by Donnie Summers
Silverado.
Some wall mounted opener controls have an extra button that can be used to prevent any remote opener from functioning.
Ours, have an LED which is solid to indicate active and flashes to indicate 'locked'.
I do wonder why the vehicles are wired so homelink is active when not keyed on, but for 'here' locking at the control pad is an acceptable solution.
I found I couldn't program my 2019LT  home link until I removed the LED bulbs from the opener the previous own installed.
That's really interesting....
High frequency interference form the bulbs?
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
