2007 Chevy 2500HD
abg001
What does the plow package and tow package on the 2007 Chevy 2500HD LT1 consist of? And what are the weight ratings for payload and towing?
Your payload should be posted on the inside of the drivers door and your tow capacity and payload c/w GCVWR can be found in your owner's manual. If you don't have an owner's manual check with your local GM dealer to help you locate one for your year/model of truck.  You will find some useful information and tips in this book.
On ‎2019‎-‎02‎-‎21 at 3:54 AM, abg001 said:
Ok, where can I find what the plow package and tow package consists of?
For kicks I googled your last question and found this:
RPO Code VYU (found on the sticker in the glove compartment)
Snow Plow Prep Package, includes 10-amp power for backup and roof emergency light, (KG3) 145-amp alternator, high-flow front bumper, forward lamp wiring harness, 1.65" (42 mm) access hole with grommet in front of dash panel, roof beacon lamp provisions with switch on the instrument panel, instrument panel jumper wiring harness for electric trailer brake controller, (K47) high-capacity air cleaner and (NZZ) Skid Plate Package
