I have had this shudder issue with my 2017 Silverado 6 speed trans. since day one. I only have 6000 miles on it now. First time I complained. Took it into local dealer about 2 years ago. They looked at it, had it over night. Told me it was "just the nature of the beast". A shudder in a brand new truck isn't anything that seems natural to me!! I have had many new vehicles and never experienced this issue before. Now, I have contacted the dealer I purchased it from and they are to look at it tomorrow. They have already told me that I wouldn't need to leave it all night as they new how to fix the issue! Here is hoping they are right!! I have a feeling when I get it there they will tell me I have the 6 speed trany and therefore no service bullitin on it and therefore they can't help me! Sure hope I am wrong!
  • 1 year later...
My transmission in my 2015 Silverado will not engage in first gear or reverse until it reaches about 1200 RPMs once as it has come up to operating temperature what do you think that issue could be? I’ve had the transmission rebuilt and it has had fluid change multiple times. Thanks in advance
  • Sad 1
Sounds like a pump issue.  If yours were mine I would want to put a Tech-2 on it and see what the solenoids are doing.
What was replaced when the transmission was rebuilt?
Im new to this forum.  I drive an 18 GMC Sierra, bought new.  Currently has 113k miles on it, mainly HWY.  I will occasionally pull a 4 wheeler, nothing serious.  It is in the shop currently getting the transmission rebuilt.  It has the 6 speed.
Had no issues up to a week ago, then it started lagging with acceleration.  Then hard shifts to complete failure.  The local transmission shop I took it to said they rebuild 4-5 a week.  Probably bigger issues here that should have triggered a recall.
  • Sad 1
The torque converter was going out and it was rebuilt back at the first of the year. So then it had the typical Chevrolet bump which I was told was a relearning process but it continued to get worse to the point I had to go back and he reset the pressures in the transmission. Then recently I had this problem mentioned. Now he’s replaced the TCM, reprogrammed it,  rebuilt the solenoids again everything else looked fine. But he thought that it may be the pump then talked himself out of that even after a dealer mechanic said that was the issue.
I have a video but it will not let me load it up you can hear that it sounds like the pump is trying to build up pressure
The 6-speeds were fine until they put them in your K2s.  GM added a thermostat which keeps the trans temps up at 195 all the time, which makes Uncle Sam happy but kills these transmissions by 100K miles.  When you get yours back, "flip the pill".  They easily run 300K miles with regular servicing under the severe service maintenance schedule.  Some have gone to 400K+.
  • Thanks 1
Just got my truck back yesterday.  How do I "flip the pill"?  I don't want to drop another $3700 in 100k miles from now.
Thx!
Well it wound up being the pump but the shop didn’t want to admit it. They bypassed the thermostat already, it was running much cooler. I still don’t have it back yet they were waiting on a new pump. Approaching 6 weeks.
Thx!
@dieselfan1 and @Grumpy Bear You're up! :)
Thx!
This is a better method in that it provides a pressure relief. 6L80/90 8L and 10L all use the same parts kit.
  • Thanks 1
  • 10 months later...
On 3/19/2019 at 10:24 PM, 1SLOW1500 said:
Love that post I have been trying to tell people how good these trucks can really be, but it's like selling a idea people just can ever believe.
If you want you tune redone that shop should cut you a break. As the credits are already paid for. I would run 91. All you need now if you dont have it yet is catch can and 8quarts of oil MAX. And you are all good to go.
Keep us posted as you get more mileage on it.
I know this is an old subject but I just had my 2014 Silverado 6 speed replaced. Never had shudder prior which makes me think it had d tune before I purchased. Shudder is really bad as I drive the thing easy. I have a dyno tuner in my area that will tune this thing but as you say, most don't understand the shudder issue and what causes it. Even my trans shop which is reputable asked me to share with them how to fix shudder in these things. Here is what I have picked up and will be giving to my tune guy:
Disable DOD
Tcc apply pressure ramp
Tcc desired slip set to 0
Apply and release set 317 and 319
Zero out the TCC slip, disable the torque converter for gears 1-4 and only allow it to lock in 5th and 6th. But I increase the speed at which it does lock so it doesn't do it at 30mph type of thing. I push it out to above 40mph and nearly 50mph for 6th gear.
Anyone have anything else to add? Thanks in advance and I hope someone see's this.
get a torque converter from the 2500 6L90,  you might also have broken fins inside the conveter.
install aux trans filter
install trans cooler, and delete the thermostat in trans
Disable DOD
That pretty much covers it.  A billet TC is a must as well.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
