9 hours ago, Cody Williams said:
Excellent photo capture of the true look of these bulbs. I agree, my photos didn't do them Justice. . I'm still impressed with mine after almost 4 months of use. No issues. ????
On 3/19/2019 at 5:41 AM, RottDawgler said:
Low beam bulbs are H11
High beams are 9005
I just installed a 4 piece set of LED lights from Sealight on my '19 Silverado Custom Trailboss.
Just make sure you buy mini or low profile bulbs as most of the LED bulbs have the large cooling fans with heat sinks mounted on the back of each bulb and you won't be able to reinstall the dust covers.
Whatever you buy, make sure the bulbs are low profile as there's not as much room directly behind the bulbs like on previous years.
My '14 Silverado Rally 2 I just traded in had room for the large cooling fans on the rear of the bulbs. But this isn't the case with the '19's.
These are the ones I just installed in my truck.
I bought the 9005/H11 4piece set.
What a difference in color and brightness.. 110% better.
https://www.amazon.com/gp/product/B07MNG5S5P/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Hope this gives you an idea of what you need to change your headlights out.
In the photo the left are the stock bulbs and new LED's on the right.
went to the link you provided and was about to order this but amazon says it doesn't fit 2019 silverado 1500??
just wanted to make sure it said the same for you before ordering these
Hey dctackett10
Yes. These are the ones. Follow my link and order the 9005/H11 4piece set and you will be all set..
Amazon hasn't updated their website to reflect the 2019 Silverados yet. They're a direct plug and play set of 4 bulbs.
On 7/14/2019 at 7:37 PM, RottDawgler said:
Hey dctackett10
Alright.  Thanks bro. Ordering them now!
On 6/17/2019 at 8:31 PM, Brutus230 said:
Here is where I got mine the description then next pic is seller info
This kit requires a re-flash? Did i read that correctly? It should be it's own circuit with it's own relay. I cant see why a reflash is required
edit: are they LED or halogen? just curious on matching them to the LEDs
Edited by tanner709
Yes...because GM is an ****. They want to charge you an additional $100+ to have them programmed on top of the $200+ cost of the kit on a truck that should have come with them in the first place. :fume:
They are LED
Edited by RUSSH
Yea I put them in and they would not work till it was flashed.  That part sucked but o well they work now and look great
that is ridiciulous. I cant justify it. I would rather buy a lightbar  or put cubes in those housings. Maybe rigid will develop a kit for the housings. Maybe i'll make my own
High beams are 9005
Just put these in my Custom and they look better than expected. Hopefully they don’t over heat with the dust covers on but I haven’t seen anybody have that issue. Now my dad needs to get some for his CTB
Have no idea how you guys got them installed.  Man. That’s tight. Ripped my arm couple times lol.  Still. Gonna have to take grille off and pull the headlights.   For the life of me I cannot get the high beam driver side bulb to lock in place. Pissing me off!!! Lol
I installed my set today, it is tight but do-able with some patience.  Bulbs look awesome so far.  I’m stoked.
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
