21 hours ago, LSX Z28 said:
I will definitely post what I find. Looking at the breakdown at the dealership, it looks like the camera has two screws that hold it to the 3rd brake light. It also appears that you can order the 3rd brake light with a camera hole, but doesn’t include the camera. Or you can get a light with the camera included, but you can not purchase the camera by itself.
I ordered the harness that connects from the camera in the brake light to the rear view mirror to see what the connectors looked like. (The picture above) I was hoping that it would be long enough to use as an extension and remove the camera from the brake light (or order a new one) and mount it on the cap. But the harness is only about 24” long. My new thought after I got the harness today would be to install the trailer camera, which already has a mount, and Is designed to be outside in the elements, and has a cable that is plenty long. I might try to order one tomorrow.
What does the wire on the harness look like? Do you think it could be cut and spliced with normal wire?
I have a trailer camera waiting for me at the dealer. I thought about mounting it to the back of the camper top and using it as a rearview mirror but wonder if it will work without a trailer hooked to the 7 pin connector. Anyone know the answer to this?
It wouldn’t let me set mine up without it being connected - but I will let you know tomorrow. I have set it all up, and will simply connect only the cam tomorrow and let you know.
Appreciate that
Even if it works it might be awkward running the wires but I'll cross that bridge when I get there
Here is a picture of the wire in the harness next to a piece of RG6. I showed it to a high end A/V installed, and he said he hadn’t ever seen a wire like that. He said it had similar properties to RG6, but you can see it is way smaller. I don’t know what the rear view camera rating is (looks like 4K to me) so I am not sure how the resolution would hold up with trying to splice in a different wire.
I would think that the camera would work in my situation, replacing the camera in the 3rd brake light, as that is already programmed to be on all the time.
I could see something in the programming not allowing a trailer camera plugged into the trailer port to work without a trailer hooked up. But who knows.
I'll get my trailer camera next week, may play with it some if I have time. Will let y'll know
14 hours ago, ArTurf said:
Appreciate that
It did not work without the camper being hooked up as well.  Not sure how the wiring goes - but I would think if you plugged one of the 7-pin test connectors up, and the camera it might work. I don’t have a test connector.
POLLAK 12741EV 7-Way Circuit Tester
Could you take a picture of the plug on the end of that camera wire, please?
17 minutes ago, 2019ArkansasSierra said:
Thanks! I guess that looks like a different connector than what I posted yesterday, so I guess that won’t work for what I was hoping it would. Back to the drawing board.
Well - that is the camera plug that comes with the truck (if it had the optional camera). The other end may just be the one under the bumper before it attaches to the combination plug on the truck itself. I’ll check. Mine didn’t have the “inside” trailer camera plug attached to the combination plug. It’s secured under the rear bumper - and you can see the empty space where it goes in the other pic I highlighted in red.
@Gypsy1962 did you get any good results after hooking everything up?  I'm in the same boat with the technology package and no aux camera option.
On 11/22/2019 at 2:34 PM, Chris Callanan said:
Best I can tell, at least in my 2019 SLT - the hard wire connections are there..  there is a connector behind the license plate that should be for a camera, and from 3rd hand information it seems the cabling is in the door/mirror for the side view trailering cameras...  so if you can get the cameras, great... what you'd be missing is the programming for the head unit to actually recognize them...  the dealer will most likely *not* do this.  Our only hope is to get somebody like WAMS to program it up for us :)
what or who is WAMS
Guys I really need some help I have a 2019 Sierra SLT with the"Trailer View Camera" Package and I have the two Aux ports on top of the 7 pin connector. I purchased the camera today for my 6x12 however whenever I connect the camera it is blank on the screen. Furthermore, I followed the installation instruction closely (not to connect the camera when the truck is running) yet there is nothing simply black blank scree. Is there something I am missing? Also the instruction manual talks about doing a calibration in the trailer app but there is no such a thing. All I have is an icon for the camera in the camera app that has the side mirrors and the trailer camera option but whenever the trailer camera is selected whether with the side mirror or not it just shows blank. PLEASE HELP !!
The only thing that I could think off that does not align with the manual is the 7 way connector. My trailer only has 4 pin and I am using and adapter to plug into the 7 way on my truck.
Edited by Aalfawaz
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
