just got the truck back from dealer  they said they could not duplicate errors and no codes found ...they need it to happen when its at dealer .problem is its so intermittent . called  GM waiting to hear back from them....this really sucks
What is the build date of your truck? Us or Mexico?
I don't know I'll have to look and get back to you I got it end of Fed...why?????
Well for example my truck was an early build us truck and has a bad rear window leak which is a known issue with US trucks built before October. If you let everyone know if yours is a 1 Vin or 3 Vin and build date, it might help narrow down the problem if others start experiencing the same thing.
7 hours ago, texasaggies16 said:
time to trade it in on a 18!
I would be to upside down . just made my first loan payment only have the truck 5 weeks
  • Sad 1
1 vin -built-in USA
On ‎2019‎-‎04‎-‎08 at 8:39 AM, Jricharc said:
Jeez, I am reconsidering picking up one of these new models if they are going to be having these issues right off the bat.  Not what should be happening when you spend $40k+ on a vehicle, plain and simple.
Never. I repeat, never. Buy a first MY. truck.
Take that from a Canadian 2014 owner with no lemon law protection.
1 vin -built-in USA
What is the first 3 of the last 6 of your Vin? Mine was 107,xxx meaning it was the 7,xxx th truck built.
255xxx
Well it's been 2 days and I have not heard from a GM supervisor...I guess I will have to call them tomorrow....just show's how much they care about there customers
Mine is 117xxx.  Does that mean my truck was the 117th built?
I could be wrong but I think I starts at 100,000 not 0
All I can say is OUCH - I do know what you are talking about with ghost issues that come and go. I found that it takes a very vigilant service manager to keep on GM to fix the problem. My wife's car (a Chevy Cruze) suddenly died and displayed three unrelated service systems in the DIC. The service manager and the tech both said it was probably one of the computers - but they also had to go through the gm troubleshooting tree before they could replace it. The tree included a couple of reprogramming the computers, replacing the battery cable and inspecting ground points, some sort of relay and finally the computer module - three weeks later. We did have a free rental car during this time and we received status updates from the dealer every other day. We know that they drove it around quite a bit after every repair attempt. The irony of all of this is that it probably cost GM more overall to go through all the steps rather than just replace the computer in the first place.
    • Very true.   However.  GM did give those trucks with the single speed case Terrain Mode.  Terrain Mode mimics 4LO minus the gear reduction and torque capability.  It uses the ABS/braking system to perform the operation.  It also gives these one pedal driving (sort of) when in Terrain Mode via the active brake during throttle lift.     Does it have its limitations over a true 2 speed case?  Sure.  But it works.
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
