Did my first oil change the other day and while I was under there I took a quick look for grease zerks and didn’t find any. Is everything sealed on these or do I just need to look harder? The owner’s manual specifies a standard cartridge grease (12377985) for “chassis lubrication” so it makes me wonder.
35 minutes ago, UGADawgs said:
I haven't greased a vehicle in over 25yrs.
I’m not sure I’ve ever greased a personal vehicle, but according to these forums, the previous gen had grease points.
Some of what I was reading was actually about the 2500, but just read that the 1500s had a couple too.
I would think only the Ujoints, but pure speculation.  It's too wet out to check right now, lol.
I checked them when I was under it and didn’t find any there either.
  • 1 year later...
i just did my 20 2500 and i realie this is 1500 forum but there was no grease from factory....i had 9 up front and sure 1500 will have lot less but if you have em grease them cuz factory didnt
HD's went from 11 zerks to 9 zerks  when the new chassis came out for the 2011 model year (same year DEF was added and the LML duramax replaced the LMM)
From Dunn's post, the 20+ HD chassis still has 9 zerks.
The LD pickups don't have zerks.
I'm not sure when they quit using them, but it was a long time back.
IIRC, it created a lot of chatter --- kinda like this thread.
Edited by redwngr
  • Haha 1
  • 2 months later...
You probably should work at a dealership then!
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
