12 hours ago, KTDanforth said:
Just curious, the install ever get completed?
i think corona got fiatdale. pgamboa bought all the parts he is going to try eventually.
  • 1 month later...
  • 4 weeks later...
I bought a complete dash out of a 2020 Silverado with HUD.  I stripped the dash and cut open the harness.  Removed the HUD circuits from donor dash.  I then dismantled my dash.  I replaced the center stack hvac vent which is narrower in a HUD truck.   I replaced the drivers side vent which is flatter to let the hud mount clear.  I cut open my dash harness and soldered the HUD harness circuits into my dash harness.  There are 5 circuits that need tapped. 2 grounds, 1 power, 1 led backlight and 1 lin bus.  Lin bus gets soldered into the cluster harness.  1 ground I soldered into the parking brake button.  The other 3 go in to the main trunk of harness.  I then cut the HUD 2 support mounts from the donor dash support and welded them into my dash support.  There are 3 mounts for the hud support 1 was already there.  I was then able to attach HUD support the mounts in my truck I connected everything and put everything back together and then HUD worked.  I did not swap windshield there is a little ghosting.  The HUD image is actually much bigger than I can capture in picture, I do not know why that is.  I am thinking about tinting windshield slightly to help with eliminating ghosting. 20210530_125917.thumb.jpg.b3673cd62bbb77152f34c1852af5ec65.jpg20210530_072433.thumb.jpg.0dcf428a0d8af74daf8d30c59a3e2dde.jpg20210530_073757.thumb.jpg.df181d9488edea85704f9f685b51a358.jpg
  • 3 weeks later...
I used the following PNs:
Mount Bracket: 23407367                                          $65
Driver Information Display Switch: 84456360           $31
Instrument Cluster: 84804721                                    $412
Instrument Panel: 84553050                                      $280   Has dash panel, HUD trim bezel, and mounting strip
Cluster Visor: 84054788                                             $70 Designed for HUD
Head-up Display: 84395830                                      $510
Outlet Duct: 23391609                                                $24  - Allows you to keep the Drivers side left defroster
Windshield: 84398043                                                $394   (Not used at this time)
WAM VIN Programmed                                                $200 + &80 round shipping
Phil’s custom harness                                                  $150 -2014 - 2018 Silverado / Sierra - HUD Retrofit Harness - Harness Dr. - DIY Done Right
are you planning on throwing some 50% tint down? the slight blurryness is hurting my eyes 😳.  what did you do about only having 1 out of 3 mount brackets for hud bracket?  i bought entire dash so i could cut those mounts out.  nice work it was a fun upgrade.
The slight blurryness doesn't bother me so much.  I may start researching for ceramic windshield tint. If anything to help keep the interior cooler.  Maybe find a piece and put it where the HUD displays for a test. Without the 2 mounts you get the HUD to bounce around a little when going over bumps.   I may zip tie the back down as you can get to it just by removing the driver console.  Since I can't weld, I'd have to get the complete frame and really tear the dash down.
  • 4 weeks later...
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
