Any chance anyone has just gone to the dealership and asked what it would run to buy the parts/swap it?  I'm pretty handy, so assume I could probably do the install as long as the wiring is just harnesses, but...it's my baby, and I kind of want it done 100% correctly...
I priced it out on GM parts and it was over $1000.  Then I was told by the dealership I can’t purchase the swap so I went online and found it.
$250 and it took me about an hour to install.  It’s a genuine GM part so it looks factory.
https://www.gmperformancemotor.com/mm5/merchant.mvc?Screen=PROD&Store_Code=GMP&Product_Code=84756948&yotpo_token=8eb9fa71abc7ab2860a90cbb96f22de9c7518619&utm_source=yotpo&utm_medium=email&utm_campaign=map
Edited by ScarletSilverado
It is just plugging in the wiring harnesses.
I called my chevy dealership and they told me it wouldn't be compatible, which is obviously not true.
I promise it is super easy. You have to undo 4 screws ( I believe they are T50s) on each seat and just move the seat to the side to get access to the 4 bolts (18 mm I believe) holding the center console/jump seat on. Once those 4 bolts are removed you have to undo the wiring harness that is on the passenger side of the center console/jump seat.
The only think you possible can mess up is removing the plastic trim on the sides on the center console. There are videos showing how to do this online.
I have the jump seat with storage right now, I was thinking about going with the whole center console replacement, seat to dash.
On 11/3/2020 at 3:44 PM, M_Day09 said:
I have a jump seat with storage in the arm rest and under the seat if anyone is looking to buy one.
THIS is exactly what I’m looking for. How much shipped to CA?
Edited by stonedigity
I did the conversion on my 2020 LT TB ....I got a full console with all the trim,brackets,harnesses,ect for 550$ shipped to my door from car-part.com...The console I received was literally brand new looking...The total swap out from my jumpseat to console took less than 1 hour...The only thing is the SD/usb inside the full console works when hooked up,but the radio freezes up when it connected...I'm think the SD/USB reader insise the console was maybe programmed for the different truck???Either way it bolts right up and is a super easy swap out ...
On 11/17/2020 at 1:37 AM, shanemoon said:
I have a jet black, cloth center jumpseat with top storage if anyone is looking to purchase. Located in Dallas. Will ship at additional cost.
Can you send me a PM with price? I'm located in Houston. My father just purchased a TB Custom and is wanting the top with storage. Thanks!
PM'd you.
I have a 2021 gmc 3500hd denali on order and I want the 6th seat! If anyone has the center jumper they want to trade or I will purchase then let me know! I am looking for one that has storage under the arm and seat, has the 2 usb and 12 volt in the back along with the air vents. Jet black leather for the entire thing is preferred to match my interior.
This isn't still available is it? I am in Little Rock, but am in Dallas all the time.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,978 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
