Just purchased a 2019 crew cab LT. It has the center seat and I would like to convert to a console. I have searched but a 2018 conversion appears to be way different than the 2019. Anybody done this yet? Looks like it might be easier to do it on a 2019.
Try checking the Mods section of the forum.  There should be a topic already on this
Just spent a good time looking, but most are just about wanting a jump seat or storage in a jump seat. Guess I'll just have to wait. I had the dealer price one and they are north of $700.00
Placed my order for all the parts (I think). About $800 into it right now. Will see what comes in. Parts department seems to think this will be all I will need.
I ordered the parts off of Gmpartscenter.net
Very helpful.
  • Like 6
Very helpful.
Are you having them install it or doing it yourself? If you do do it your self you should takes some pictures of the process to help out other guys that want to do the center console swap.
Looking forward to your progress. This is something I want to do badly. Want to add the wireless charging as well.
Thanks for tackling this.
I will be installing myself. I'll try and get pictures of the progress and any issues I stumble across. There will probably be extra parts that I missed.
  • Like 4
Can I buy your jump seat off you if it has a center console lol.
Or or anybody else who may be switching their jumpsest w/ console to a middle console. I’ll take it lol
Do you have a console currently?
No console.  Looking for one. I have the middle jump seat.   Looking for a console or jump seat with storage
Guys with a Custom Trail Boss will definitely be interested in buying the jump seats.
  • 1 month later...
Any updates or progress on this?  I'm planning on doing the same.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
