On 2/8/2021 at 9:39 AM, 175vTrailbossLT said:
Hey guys. Does anyone have any real world examples of a 1/2ton truck towing another 1/2 Ton truck?
I have a 2019 trail boss LT 5.3L v8. Want to see if I can tow my 2011 silverado extended cab also with 5.3.
I ran some numbers and I am coming up with a technical “yea” I could do it. But I’m planning on a 6 hour drive over the grapevine in CA (big elevation changes). I used an online calculator and had to input a couple variables like - guessed that the trailer would have GVWR of 10,000lb (pj trailer buggy hauler model) and that the trailers “cargo weight” is simply the curb weight of the 2011 truck being towed which I put in as 5500 lbs.
Here is the trailer sticker from my truck.
I’m debating renting a 3/4 ton truck from enterprise instead.
I’d say you’re fine
For the guys using WDHs, who is running a Blue Ox? My dealer is throwing one in with the new trailer we bought. From what I’ve read is a good option so figured what the hell. But I’d like to hear some feedback from you all on them
  • 3 weeks later...
Picked a new weekend toy today, drove about 100 miles with empty trailer and 100 miles back loaded. Averaged 11.5 MPG for the whole trip. Towed like a dream, first time towing with this truck.
23 minutes ago, eppieguy said:
Sure, why not more.
Nice!   How did you like the U-Haul car trailer? I know they are relatively light and have surge brakes so no need for a brake controller. Asking cause I may need to use one in the future.
Well it actually towed great, it appeared to be an older trailer but it had new tires on it. The surge brakes worked well and seemed to be very light. I had it up to 71 MPH loaded and it did just fine. I’d rent again if needed, and only cost me $60.00 for the day.
Still a bit of a work-in-progress... been having a hell of a fun time learning how to weld and this trailer is going to end up with way too many fun little things added to it
I listen to a program called car pro. It’s been on awhile. The personality used to own car dealerships. He gets to drive a different vehicle every week. He seems to lean Toyota for hybrid and cars. Ford for trucks for pulling and Ram for comfort. He has dealers nationwide that are on his website that offer hassle free car buying. I belonged for awhile. Among other perks were free carwashes and premium services. His opinion on part time towing is. Under 11K 1/2 ton properly equipped is the way to go. Being seemingly a Toyota guy his pick was a Ford 3.5 with the 373 gear. My only real experience is with gooseneck- fifth wheel I figure I pass this on. In sure any properly equipped 1/2 ton would be the same.
That's interesting because I talked to one guy who owned both an F150 and a Tundra. He hated the Toyota with a passion but admitted that it towed better than the Ford.
If I was to buy a new truck right now. It would be a Toyota. A V-8 that’s not a Frankenstein. But I believe the 3.5 has more horsepower and TQ. For towing I’d only go fifth wheel. But that’s just my preference.
On 1/21/2021 at 8:39 PM, David Withrow said:
Went from Ohio to Tupper lake New York. 2 Atvs and lots of hunting gear.
Specs on this trailer, please? Truck specs and fuel mileage with trailer? Thanks
Edited by Jim165
More questions
Just picked up my dream camper Towing my xlite Cougar 28rls.  6400 dry lbs and maxes out at 7800. Using my new andersen wdh. Tows like a dream.
Edited by Edwin Escalet
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,141 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
