3 minutes ago, OnTheReel said:
They are the ones GM sells made of matte black plastic.
https://www.shopchevyparts.com/decals-and-emblems/2019-silverado-1500-tailgate-chevrolet-lettering-decal-package-black/84370615-p-92300682.html
I would say they are probably very similar to the flat ones from BD, but haven’t seen those in person. Mine have no dome on them at all.
i appreciate the reply. the chevy link states they are vinyl. you mentioned yours are plastic. i prefer vinyl as i don't want a raised plastic object with visible edges. yours looks the best in my opinion so far though. love the black on black.
They are thicker than normal decals and have a pretty hard surface, I would consider them closer to plastic than vinyl.
It makes them a lot more forgiving to install...no chance of bubbles or a piece of lint telegraphing through the sticker, and you do get a “second chance” to line them up correctly if you start one crooked. But there is a slight edge on them. Also, after I installed, there was a bit of adhesive residue on some of the edges that I cleaned off with alcohol, and then I was really happy with it.8CA0BD86-3D74-4890-85F2-3A1ECC14F44B.thumb.jpeg.f13f73c7bb4366772a18657e13cac3a8.jpeg
That’s exactly the picture I was looking for. Thanks for the picture and replies. I think this will Be the one I order. :)
Here is 3 trucks we did at work.  The GM kits, matte black or silver is what they offer.  Iridescent Pearl, Silver Ice and North Sky Blue:
Edited by newdude
  • 4 months later...
Wow fellas, the red letters on the NorthSky Blue looks awesome!
So does the Murica!!
Anybody happen to have black with red outline on white? That has caught my eye on the website but there's not a really good pick of the entire tailgate.
On ‎10‎/‎20‎/‎2019 at 8:55 AM, Ebrown1120 said:
I have the black with red outline on my satin metallic.
Looks good... even better with the other emblems shaved.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 396 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
