These make that A$$ pop right in your face lol. Went with the regular black (Not Satin) from BDTrims.. easy install. Ordered straight off amazon from the BDTrims page. Going for a simple yes it’s all blacked out look.
  • 1 month later...
looking for black letters on my northsky blue rst, i just need to see one already done to see if i like it, and not waste my money.
  • 2 months later...
  • 2 months later...
I am right there with you on this. I just got a high country so I honestly don't know what would look good or bad on it....
I got some BD trims domed black with silver outline for Christmas from the wife. They have been stuck in Florida for the past week? Hopefully they come in. Won’t put them on till spring so not huge deal. Wanna make sure weather is nice and warm so they stay on.  Too dang cold here in Midwest right now.
  • 7 months later...
Just bought my RST last week and came across this thread. I like the look of the chrome letters along with the factory emblems.
  • 6 months later...
I have a northsky blue custom trail boss with red tow hooks I don’t know if I should make my letters red or black them all out
Can you do black with red trim?   I did mine black with silver(chrome) trim.  Really pops.
On 5/11/2020 at 5:38 PM, psk256 said:
Amazon around $35.  I like how you don't see the "texture" unless you're right on it.  Just enough contrast for me, and kinda matches the headlight carbon look.
Looks good, the texture is unique!
On 10/30/2019 at 5:23 PM, curly said:
Anybody happen to have black with red outline on white? That has caught my eye on the website but there's not a really good pick of the entire tailgate.
I know this post is a couple of years old but here is the BD Trims raised black w/red trim letters on my Silverado tailgate.  Very clean look & easy to install.  Removing the "Silverado" & "LT" tailgate badging today.
Edited by AZBadgerFan
That looks good on the white!
thank you so much, that looks awesome on your truck
  • Thanks 1
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
