10 minutes ago, Grumpy Bear said:
I used to be, when I had good ears, quite an audiophile. 1970's component days and all. So my favorite store had 'listening rooms' where they would set up your choice of equipment and you brought your own wax and you got to listen, mix and compare to your hearts delight. At the end of the day I walked out with a $150 Pioneer belt drive table with a $150 upgrade Osawa low mass graphite head and reverse wound MIC armature with Sapphire stylist. To me and to the "O" scope I could detect no difference that made a difference between it and a $2K Bang & Olufsen direct drive.
When I look into a motor at life cycle end of the vehicle and see it as clean as the day it was build and measurements still well inside new spec I don't ask what more I need from my oil. I ask what more I need to know to keep the thing it is propelling last longer. It has to matter to make a difference.
I never looked at the lower shelves of AMSOIL or Red Line or MPT or TORCO because they are similar to what it on the shelf at Walmart, Amazon or O'Reilly's. I've used those oils and have suffered using them. I watched my father use those same shelf oils with great success but never at the OCI's being recommended. By the time the OCI got short enough to get a similar cleaning result it cost more than RLHP.
HUH???   :)
Development of Modified Pag (Polyalkylene Glycol) High VI High Fuel Efficient Lubricant for LDV Applications
Abstract
Engine oils play a critical role in friction reduction. Improvements in engine oil technology steadily improved fuel economy as the industry moved through ILSAC GF-1 to GF-5 specifications. These improvements were influenced by changes in base oil chemistry, development of new friction modifiers and their treat levels, and the total additive package consisting of various other components. However, the improvements are incremental and further fuel consumption reduction opportunities are becoming more challenging. Polyalkylene glycol (PAG) based engine oils are being explored as a step forward for significant fuel consumption reduction. Although PAG fluids are used in many industrial applications, its application as an engine oil has been explored in a limited way. The objective of this project is to deep dive in exploring the applicability of PAG technology in engine oil, understanding the benefits, and limitations, elucidating the mechanism(s) for friction benefits, if any, and finally recommending how to address any limitations. The project was designed in four steps, starting with selection of lubricant technology, followed by friction and wear evaluations in laboratory bench tests which are relatively simple and inexpensive and also served as a screener for further evaluation. Selected formulations were chosen for more complex engine component levelmore »
Authors:
Gangopadhyay, Arup [1]; McWatt, D. G. [1]; Zdrodowski, R. J. [1]; Liu, Zak [1]; Elie, Larry [1]; Simko, S. J. [1]; Erdemir, Ali [2]; Ramirez, Giovanni [2]; Cuthbert, J. [3]; Hock, E. D. [3]
Publication Date:
2015-09-30
Research Org.:
Ford Motor Company, Dearborn, MI (United States); Argonne National Lab. (ANL), Argonne, IL (United States)
Sponsoring Org.:
USDOE
OSTI Identifier:
1234442
DOE Contract Number:
EE0005388
Resource Type:
Technical Report
Country of Publication:
United States
Language:
English
Subject:
36 MATERIALS SCIENCE; 32 ENERGY CONSERVATION, CONSUMPTION, AND UTILIZATION
Edited by customboss
6 minutes ago, customboss said:
Boy do you have to be careful when you Google that company! Say MOTOR OIL afterwards or you wind up on a dirt road in Mississippi. 😬
So what happened to these guys?
5 minutes ago, customboss said:
file:///media/fuse/drivefs-d11db967b82af1bb5bfe474b2bac9d81/root/VOA%20&%20Reference%20&%20Labs:contacts/NOXIDANT%20fuel%20additive%20FORD%20PAG%20study%20%20/FORD%20PAG%20tests%20%201234442.html
Broken link? I can't open it.
Break time. :)
Edited by Grumpy Bear
1974 paper
Break time. :)
updated
1974 paper
Break timage.thumb.png.58208e3b6a3c62ee89c8392b38940244.pngime. :)
updated
I just remember them going broke about 1976 when Mobil1 came out and Amsoil was going strong with POE primary base oils.
B/S Labs finally getting with the program.  Also, notice in the Red Line UOA that TAN>TBN.  Oil is shot and now acidic.
Edited by VicFirth
That's the reactivity I speak to.
Clean reference Lubrication Engineers 5w30 we tested in VW with APR tune and accessories.
Note glycol trace. Grp III BASE
That’s an additive like Redline used in past.
I found my 1992 paperwork from Roy Howell original formulator for Redline.
My 2 cents.
I use Amsoil OE motor oil in our Hyundai, 2.4 L non turbo. Quieter motor and stopped slight oil usage. I'm doing 5k OCI's, I'm not going to rely on motor oil to keep my engines clean, oil changes work for me.
I also use Amsoil OE trans fluid in this car which has no trans filter, smoother shifts.
Amsoil fluids in diffs and transfer case. I still believe better products than off the shelf stuff.
Same experience with my Kawasaki SXS, this motor lives between 5k - 7k rpms, red lines at 9k. Quieter motor and drivetrain with Amsoil products.
Yes better quality oil, fluids are available but I just change mine more. Pulling a valve cover will show how clean/dirty things are, which I have done.
  • Thanks 1
  • Haha 1
    smandy
    smandy
  • Who's Online   4 Members, 0 Anonymous, 509 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
