7 minutes ago, Dub1796 said:
Looks awesome,
Huge fan of the red tow hooks on this body style!
77 and sunny in the Seattle area today, what part of BC are you in?
3 minutes ago, JimCost2014 said:
Looks awesome,
Just up the coast from you. I'm in Vancouver, BC
50 minutes ago, 1SLOW1500 said:
DUB 8-ball S213 in 24x10?
What rubber is on there I need wider wheels.
You need some race stars.  Way less mass to get moving. 24s with tires are ckose to 90 lbs.  My race star setup weighed about 50lbs a wheel with tire
I know but I like the 24" look and also how low is a 3/5 drop with race stars? Best would be 20"or 22" but again need width and all I see is 9 or 9.5
You can do the 1320 rear brake conversion and run a 15x10 in the rear with a 295 or a 325 wide.
I love your truck. But the one thing is the wheels. So much more moving mass.
Yup s213 8 ball on 305/35/24
Is the truck lowered?
Looks like it just has a drop shackle
Drop shackle and leaf block removed in the rear. The front will be lowered with belltech struts when I get time
How is the ride quality with that beautiful Sierra you have.
I couldn't let that joint sleep outside brah, I would never get no sleep.
I hate traveling sometimes with my
#1 Star vehicle, due to it staying outside in the parking lot.
BTW.
Where did you purchase the front GMC emblems, color matched the body?
I just took off the oem 22s and I would say the ride quality is almost the same. With the rear lowered, the truck isn't top heavy in turns anymore.
Ya i dont like leaving it outside, but my dashcam is hooked up to my WiFi, so I got 24hr motion sensors and notifications lol. Also, my truck has a tilt sensor in it that texts me.
Bc the truck is summit white, I was able to use Plasti dip on the emblems. I use to paint them, but they would get chipped every winter and I would have to repaint them. Then I switched to vinyl, but the vinyl would get dried out bc of the sun/heat and chip/crack. Plasti dip is the most durable product I've used on emblems
