     Hello, I have a brand new 2018 GMC Sierra SLT Z71 8 speed Crew Cab with the 5.3 engine. I know this has been discussed before, but I haven’t heard anybody say this low of oil pressure
(15 psi) at idle, stopped, in gear, after driving for about at least 30 minutes. Yes, I freaked out the first time I noticed it when the truck only had about 250 miles on it. It now has a little over 2000miles on it. When driving at speed of about 45 miles an hour it’s about 35ish psi pressure which I think is ok, and all other speeds it seems ok. It’s the hot idle (about 600 RPM)while stopped and in gear low oil pressure that has been bugging me ever since I first saw it. It only goes this low after driving for at least 30 40 minutes in warm 85* weather. I know about the two stage oil pump but this just seems low.
        Can anybody please tell me if their trucks run this low of pressure stopped, idling, and in gear, after completely being warmed up? It will put my mind at ease if others have the same results. Even pics of the gauge.
        Thank you,  Steve
Most vehicles will have lower oil pressure in gear warmed up. If it was a stick you could get it down lower by engaging the clutch a bit. There’s a light that would come on if it got to low.
It takes 8 quarts of the 0w20 wt oil which I know is thin.
Just getting this low on a brand new 2018 Sierra seems crazy as when the engine gets older, with miles on it, it will probably go lower..
Never had warning messages thou.
I know the dealer will tell me it’s normal until the warning message appears..
Anybody out there actually have oil pressure that gets this low?
So I should have nothing to worry about?
 BTW Thank you so much for your replies so far.
It is possible that the one oil pressure sensor that is on your vehicle is one that it's settings are reading at the lower side of average if that makes sense.
 That could be.....
 The way I look at it if other people are getting this low of readings in these conditions, I should be good at the end of the day, I would think.
My 2018 CC w/ 5.3 w/ 6sp trans does the same at various intervals.  Does not seem to matter if at idle or on highway.  Voltmeter also will dip low too but never had any warning lights/messages.  I have nearly 30k miles on mine now.
Voltmeter dipping low is normal. GM thought it’d be cool to cause a panic doing this. It’s to prevent overcharging of the battery.
As far as oil pressure, looks ok to me. I’ll drive mine and get back to you. Pretty sure mine’s in a similar spot.
My oil pressure is all over the place in certain conditions. Especially when the transmission shifts. 2016 Silverado Z71 Crew Cab 5.3L 6spd
 DirtyAndy, it would be great if you got back to me on this.  Problem is you have to drive it for over 30 to 40 minutes to get the readings that low, as far as how mine is.
Thank you guys for all these great replies. So you guys are actually getting as low as around 15 pounds PSI according to the lines on the gauge in the dash?
 The more people that chime in on these low oil pressure’s of about 15 PSi,  on this model year, I think, will make a lot of us feel better that it’s very likely normal .  I would’ve been OK  in the first place, if it was a little above 20 psi at the lowest reading .  All my other previous trucks, never went below around 30 psi stopped, at idle, in gear, after a long drive.
 The more people that chime in, give us a better idea of how these new trucks really are or what to expect...
Mike,  in my own past experience having the oil pressure jump up-and-down as you’re on the gas and through shifting of the transmission is perfectly normal with any model year in my experience.
In the old days, 12 volts was sent to alternator to kick on charging system when key turned on. Resulted in overcharging of batteries. PCM now cycles alternator on and off to keep from boiling the battery off.
0 weight oil in Cali in hot temps getting low oil pressure....no fear.
You can get a 5.3 with 20k miles from a crashed truck on Ebay for $2k. Keep trusting GM and just drive it. Insufficient Oil Pressure= AFM lifter failures via the Melling Bulletin from last year. They make the collapsible lifters for 4 cylinder shut down.
https://www.melling.com/wp-content/uploads/2018/03/Melling-tech-bulletin-on-GM-LS-Deactivation-Lifter-Issues-3.1.18-1.pdf
Read what Melling says oil pressure is supposed to be.
Edited by Paintor
Yeah thanks. I’m not worried about it. Funny thing is that I didnt mention that my oil pressure actually always goes up, never down. A little different than the OP’s situation.
15psi is too low. I wouldn’t feel comfortable driving it.
Hot idle mine hovers in the low 30’s and cruising I see 50+ psi.
My 2018 5.3 will drop to 15 psi at hot idle after it gets good and hot, usually after a run on the highway in FL heat.  Im assuming its normal operation considering how thin the oil is required to be.
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
