My 19 HC with the 6.2 / 10 speed is driving me crazy with a squeaky belt or pulley. It is very pronounced on a cold start at idle but goes away in about 10 seconds. From cold start through engine at full operating temp you can hear the squeak while driving at 1100-1800 rpm but only while the engine is under a light load. It is going in to the dealer tomorrow, I will post with what they found. Just for reference is was built in January 2019 in Indiana.
Edited by BeardBros
Could be a harmonic balancer issue. With the motor running look at the balancer for movement.
mine does that about 15 seconds cold start let us know what dealer says
thanks
It's under warranty, so I just dropped it off at the dealer and told them to fix it.
Dealer is still working on finding the source of the squeaking. The squeak on mine is so loud that I can hear it at highway speeds with the windows up. It occurs between 1100-1800 rpm under light throttle at any speed. No way can I stand to have my new $65K truck with 5000 miles on it sound like my neighbors 1985 beater F150! I told the dealer to keep it until it is fixed.
Edited by BeardBros
I think I have the same thing on my 2019 HC.  I was actually coming on the forum to see if it was just me.  At first I was thinking ping (bad gas and like what you said about light load) but i have heard pings before (other vehicles) and it wasn’t really that but I tried different gas anyway just to see.
It sounds like maybe some baby birds faintly squeaking here and there but isn't constant.  By not constant I mean I hear it every time I drive but only here and there under load.  It can be first thing in the morning, cold, hot, afternoon, highway, etc.  I think most people wouldn’t notice it much but I do.
I have the exact same noise, belt/pulley noise that is present after I cold start.  It's there for 30 seconds and disappears.....it's driving me nuts.  i took it to the dealership last week and they could not duplicate the noise, hopefully this will get figured out.  My nearest dealer is an hour away so its a pain to get it over there and wait.
My squeak is not come and go, I can reproduce it on demand and showed the dealer. As my mileage increased, so did the loudness of the squeak. Since I am in farm country, 80% of my dealers business is trucks, so they know what they are doing on these Silverados and Sierras. I am confident they will find the source of the issue. They gave me a 2019 Xcab Z71 LTZ to drive around in until my HC is fixed.
Edited by BeardBros
I’ve got a 6.2 hc with same issue on startup and cruising at same rpm range. Dealer said they didn’t hear or couldn’t replicate sound. Let us know if anyone finds a solution.
Sounds like a pulley or even a small exhaust leak on passenger side of engine
I talked to the guys at the dealer yesterday and they are able to reproduce the squeak and are working on a solution with GM. They seem to think the squeak is coming from the exhaust system. They took multiple new trucks off the lot, 6.2 and 5.3 engine with 6 and 10 speeds,  and tested them to see if they could hear the noise and it is present in most of them but very slight. That is how mine was, very slight squeak when new but now that I have almost 6K miles on it the squeak keeps getting louder. Maybe I will have to put long tube headers and straight pipes on it, then I will not hear that squeak for sure!
If it's the same sound I hear. When I put my exhaust on it is much more pronounced. It almost sounds like a tinny kind of sound like when you go from stock exhaust manifolds to headers. Its definitely in the exhaust.
Hoping a solution is found... the 6.2 qand 10 speed is an awesome combo.  The squeak is mild, but not the typical type of noise id say is acceptable.
Im having a cat back installed next week, ill see if the dealer can take a second look.
From what i could tell, it was exclusive to the passenger side, and seemed to be coming from either the exhaust manifold or potentially the o2 sensor just down from it. Could even be a heat shield thats rubbing when the engine is at the right rpm range causing a vibration.
Troubleshooting shouldnt be too hard, but i was by myself. Need to jump the rpms to the 1200 range once warmed up.
Just an update on mine....we are pulling the travel trailer on a trip and it seems like its getting louder when we cold start and I can hear it now on the highway between 1000-2000 rpms.  6,2 10 speed also. It sounds like we have the identical problem.  Once its warmed up I can hold the brake while in gear and get it to squeak.
On another note we are pulling around 7000 lbs and it has exceeded my expectations...we have pulled some good grades getting into Oregon.  My last truck was the LMM d-max so i was concerned about going back to the gas motor but I am impressed with the 10 speed and power.
10.8 avg MPG
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
