Here's my build
Specs:
  • 18x8.5 +0 Black Rhino Chase Rotary Forged in Brushed Gunmetal
  • 295/70/18 Falken Wildpeak AT3
  • ReadyLift 1.75" Level Lift
Very minor rubbing resolved with minor trimming. I created a post on our site of the trimming requirements for those looking to go with a larger set up on the AT4: https://wheelsasap.com/gmc-at4-oversized-tire-trimming-guide/
Edited by WheelsASAP.com
grammar
  • Like 7
On 3/30/2020 at 3:40 AM, Trevor Munsell said:
285 45 22s on oem replicas. I went the budget route to get me into some 22s. Now im wanting to upgrade for a little more sidewall to either 275 50 or 305 45s. What y'all think?
Can you give some info on your wheels? Brand, spacers if any, website?
Custom Offsets. 4play cv43 gloss black. 3/8"hubcentric spacers added to order for $63. Ride great..no vibration. Got for unbelievable price.
On 5/2/2020 at 10:24 AM, WheelsASAP.com said:
Specs:
Thanks for this - great resource!!!
Anytime my friend! Feel free to PM me with any questions you may have.
On 4/22/2020 at 8:08 AM, loud_pipes said:
ReadyLift SST, Atturo Blade XT 305/55/20 (33x12.5), Moto Metal MO970 20x10 with 0 offset
991e784d7dd1d263ba13ce3d27a5bd14.plist118874e57086df09a6a99311aa0877b5.plist991e784d7dd1d263ba13ce3d27a5bd14.plist
Did you need to use spacers for the wheels?  Looks great.
Mine is a 2020 Custom 4x4 with 5.3L (NOT a trail boss)
35x12.5x20 Atturo Trail Blade X/Ts (Measure out to 34.92” and 12.52”)
2.25” Pro Comp level up front (actually sitting .75” nose High at the moment so getting a 1” Rear block put on soon).
No spacers. No trimming. No rubbing (although to be fair, I deleted the rock/mud guards as soon as I got her)
Mines a 2019 Silverado RST
I went with a 3" Superlift
Wheels are a 20x10 -18mm Fuel Rebel wrapped in a 285/60r20 Nitto Ridge Grappler
That comes out to be a 33.7" Wheel setup
  • Like 7
Hey thanks for the info! I got a couple more questions tho?. Did you need the spacers to clear the calipers or just for the look. Were the factory wheels studs long enough to take the spacer and the wheels no problem?
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
