How does it ride?
Sent from my SM-G930V using Tapatalk
Wow looks great! So you are basically at trail boss height with the 2” level kit and can fit 35s on aftermarket offset wheels
Fuel Shok Bronze 18x9 +1offset
with the Stock Duratrac tires - no additional lift or level
Discount Tire had ordered me a set of black lug nuts, but they were delayed so the chrome lug nuts are temporary.
20x10 fuel assault -19 offset, centering rings, no spacers, 295/65 ridge grapplers, 6" fabtech lift, no rubbing
  • Like 3
On 3/5/2020 at 7:41 AM, KillerOfMillers said:
18x9 +1 Fuel Shok
295-70-18 Falken Wildpeak AT3
I like this set up and stance. Looks good. What suspension setup are you on? any rubbing and/or cutting involved?
Had some rubbing, a little minor trimming on mud flaps took care of it.  The front is lifted 1.5" over stock using FabTech DirtLogic coilovers, the rear is stock height also using DirtLogic shocks.  Kit also included Fabtech upper control arms.
On 7/15/2019 at 12:09 AM, GJM32387 said:
Fuel Rebel 20x10 -18 Offset
No spacers
Nitto Ridge Grappler 295/55/20
Factory Trailboss Suspension
Slight Rub on mudflap on full lock.
For stock, it sure sits level !
On 3/11/2020 at 3:41 PM, Troger said:
Nice looking truck.  Were the side badge/vents easy to replace?  I'm looking at changing mine to those.
It's a W/T. That's how it came.
On 9/20/2019 at 6:21 PM, foxcoupefan said:
17" Method MR 312s. 35/12.5/17 KO2s, Baja Kits Chase Kit Suspension (Front King coilovers w/remote reservoirs, boxed upper control arms, rear Kings w/remotes, 1" lift rear) . No rubbing.
Love the setup - just ordered the same kit for my 2019 Sierra SLT.  What offset are you running on the Methods, what height are you running on the coils, and did you get the 1" block to bring it back to level (if so - where did you order the block)?
Sorry for all the questions, but I should be installing in the next couple of weeks.
285 45 22s on oem replicas. I went the budget route to get me into some 22s. Now im wanting to upgrade for a little more sidewall to either 275 50 or 305 45s. What y'all think?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,236 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
