On 7/15/2019 at 3:09 AM, GJM32387 said:
Fuel Rebel 20x10 -18 Offset
No spacers
Nitto Ridge Grappler 295/55/20
Factory Trailboss Suspension
Slight Rub on mudflap on full lock.
Could you show pictures from back or front to see how wide the tires look? Also how much trimming was needed and does it still rub. Looking to get exact setup. Looks amazing
Edited by Woody4444
2 Inch Rough Country Level Kit, 18 X 9 Black Rhino Alamo Rims with LTX275/70-18 Michelin AT2 Tires.  I wanted a less aggressive All Terrain tire.
Edited by Northwestern
Has anyone run the Kenda Klever RT? Was looking at Ridge Grapplers, but the Klever also has a look I want.
On 7/9/2020 at 4:23 PM, Smrtasp said:
Finally got mine done. 2019 Denali 4x4 with 2.5 front level and 1.5 rear level using SuspensionMaxx kit. Wheels are 20x9 +1 Fuel Rage D711 with 295/60/20 Nitto Ridge Grapplers. Had to do some minor trimming on the backside of the wheel well carpeting and a little to the inside edge of the mud flaps.
Update on mine for those that have been asking how the ride is. The ride is definitely nowhere near like it was and its actually bad in some cases. I was completely expecting a firmer feel and actually wanted a bit more feel to it. I’ve got this annoying issue with the rear hopping all over all the time. I've tried a number of different air pressures all the way down to 30 in the rear cold and no better. The front is butter smooth. Unfortunately in CA, every highway is under construction and with the new tires it’s just a rough ride all the time. I’ve had them balanced 3 times now and even had 1 tire replaced for being impossible to get balanced. I've also had the level kit checked to make sure nothing came loose and everything torqued and no issues there. I even called Suspensionmaxx and had them go over things with me just to make sure something wasn't installed wrong by the shop. One thing they and the shop I worked with pointed out is that with the ARC system, it could be that the heavy duty tires coupled with the stock leaf springs which will deflect a lot more are causing the ride control to attempt to constantly smooth things out which is in turn exaggerating things.
I am now looking at putting Deaver leaf springs. Their design is such that it should smooth out any leaf spring based suspension as they use many thinner leafs vs a few thick ones and that on its own will remove some of the natural truck bed bounce we all have anyway. I don’t need it back to stock as I actually prefer a bit more feel of the road but it’s no longer comfortable to drive above 70. Local driving up to 55 is fine but once you get up to highway speeds on anything that isn’t 1000% perfectly smooth it’s pretty annoying.
I think you are onto something with the ARC. You have to keep in mind that your new tire/wheel setup is probably close to 25lbs more of unsprung weight per corner due to the LT tires so they computer is having a hard time keeping up with that amount of rolling mass and constantly trying to adjust.
Nitto does make the Ridge Grappler in a P Metric XL 4 ply 305/55/20 which is about 18lbs lighter than your current tire. Only about .6" shorter too. Might be worth swapping to those - your ride quality should vastly improve.
Edited by hotrodz37
I was running the 22s so this new setup is only about 12lbs more per wheel vs 25 but yes they are definitely heavier. I had originally looked at those 305/55s and while they are about .5 inch shorter (The 295/60/20 is a 34x11.5) they are also nearly 1 inch wider and there were concerns about rubbing with the offset of the wheel I chose - 20x9 +1 offset. Running those would also get me under the weight of the stock 22s and a shorter tire but I will have to do some measuring to see what another inch of tire does with rubbing on the UCA. I'm already getting a minor rubbing at full lock with these so anything wider will probably make that quite a bit worse.
Edited by Smrtasp
Threw new wheels and tires on today.
17x9 (-12) Method 312’s with 305/70/17 Toyo Open Country RT Tires.
  • Like 5
Went back and double checked the wheel and tire weights comparing the OEM 22s vs my new setup. Its actually a 19lb difference (Stock is 85lbs total and current setup is 104lbs) so quite a difference. If I change out to a 305/55/20 Nitto that will drop this to 89lbs so only a 4lb increase over stock but a 15lb difference with my current setup. I must have mixed up one of the tires when I was originally researching all of this as I was looking at a ton of different combinations. I also measured the current amount of space between the current 295/60 tire (runs at 33.9 x 11.77 width per Nitto) and my UCA and its right about 1.75 inches on each side and that was measuring off of the raised tread blocks. The 305/55 runs at 33.2 x 12.44 wide on a 9.5 inch wheel which I think will settle more into a 12.25 on a 9 inch wheel plus they are a bit shorter. Should be plenty of room and I have already done a bit of mud flap trimming to better accommodate the 34 inch tires on there now. Needless to say I went ahead and ordered the 305/55/20 Nittos today with the shop I use agreeing to buy my originals back at a decent price as they only have about 1,500 miles on them. I wont have time to get this done until the end of the week at the earliest but will report back once its done.
Finally pulled trigger on tire upgrade. 285 50 22s. Look so much better than anemic 285 45s. Are 10 ply so do ride harsher and I'm sure are sucking more gas...but look great none the less. Went with Radar Renegade AT5. Got great price on EBay.
On 8/4/2020 at 8:39 PM, 808 HI said:
Tuckin 24s on 33.5” tires.
Hi Mark,
Great looking wheel, any chance of directing me to some more information about them?
6 minutes ago, Puttnutt24 said:
Hi Mark,
24x10 +31 offset
6x139.7 bolt pattern
78.1 hub bore
295/40 Atturo AZ800
Wheels are for sale btw.
I asked this in the Mods forum but got zero response, can anybody answer?
I have a 2020 AT4 that came with the 18" wheels.  I'm going to upgrade to 20" after market rims with a +12 offset.  My question is can I go to a 285/55 or 285/60 without any problems?  The truck isn't leveled and I don't plan on doing it.
thanks.
    LCH14
    LCH14
  • Who's Online   5 Members, 0 Anonymous, 758 Guests (See full list)
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
