Tboykin51 Posted June 6, 2021 Posted June 6, 2021 Have a 2020 1500 RST. Stock suspension. Looking at putting a 3.5” - 4” kit on the truck.. want to run an aggressive looking 35” tire on stock 20” wheels but don’t want serious rub.. anyone running a similar setup? Any pictures out there?
diambo4life Posted June 9, 2021 Posted June 9, 2021 (edited) I installed these awhile ago but this is my 5.3 Elevation. It is levelled (in the rear). 20x9 Fuel Rebels on 33" Kendas. Edited June 9, 2021 by diambo4life 1
puppykat33 Posted June 13, 2021 Posted June 13, 2021 Here is my setup Fuel Vapor 20x10 -19mm offset Nitto Ridge Grapplers in 275/65/20 I put on ready-lift 2inch leveling kit did a mudflap bracket delete with trimming the innermost portion of the flap and zip tied the liner in one spot. No rub at all 2
PureZ71 Posted June 20, 2021 Posted June 20, 2021 Replaced my stock 18's with 2' spacers for a set of Fuel Block D751 (18X9, -12 offset). I believe this offset is just the perfect amount for these trucks. http://www.fueloffroad.com/wheel/14570/fuel-1-piece-wheels-block-d751/?finishID=4434&lugs=6 6
cseaman Posted June 22, 2021 Posted June 22, 2021 (edited) BC Forged TD01 18x9, -15 Cooper Discoverer AT3 XLT 295/70 Stock height in the garage pic, RL 2" SST in the driveway. https://i.imgur.com/uDZUDVi.jpg?1 https://i.imgur.com/vSbtyq6.jpg?1 Edited June 22, 2021 by cseaman 2
Trevor Towers Posted June 30, 2021 Posted June 30, 2021 (edited) Used this forum to pick out my specific wheel and tire set up so I’m returning the favor! 20” Vossen HF6-4s 20x9.5- +15 offset. 275/60R20 Falken Wildpeak AT3W. it has a 3” Superlift lift kit. The tire size is same as stock on the stock 20” OEM wheels. There is zero rubbing at full turn. This setup gives a similar look to a leveled AT4. Edited July 1, 2021 by Trevor Towers Adjust wheel specifications listed erroneously. 2
PandonSF Posted July 1, 2021 Posted July 1, 2021 14 hours ago, Trevor Towers said: Used this forum to pick out my specific wheel and tire set up so I’m returning the favor! 20” Vossen HF6-4s 20x9 - 0 offset. 275/60R20 Falken Wildpeak AT3W. it has a 3” Superlift lift kit. The tire size is same as stock on the stock 20” OEM wheels. There is zero rubbing at full turn. This setup gives a similar look to a leveled AT4. Looks great! Do you happen to have a photo down the side showing how much poke there is?
Trev Towers Posted July 1, 2021 Posted July 1, 2021 10 hours ago, PandonSF said: Looks great! Do you happen to have a photo down the side showing how much poke there is? I do. It should be somewhere around 1” of poke over factory. Also added a picture of the clearance at full lock. I wasn’t interested in going any bigger than the stock tire sizing because I didn’t want to impact fuel economy too much with weight, overall I believe the new setup is just a touch lighter.
PandonSF Posted July 1, 2021 Posted July 1, 2021 2 hours ago, Trev Towers said: I do. It should be somewhere around 1” of poke over factory. Also added a picture of the clearance at full lock. I wasn’t interested in going any bigger than the stock tire sizing because I didn’t want to impact fuel economy too much with weight, overall I believe the new setup is just a touch lighter. Thanks, that looks good. I actually had ordered these wheels a few days ago but in a +15 offset and 9.5” wide. Didn’t realize they had the other offset and widths available.
Trevor Towers Posted July 1, 2021 Posted July 1, 2021 13 minutes ago, PandonSF said: Thanks, that looks good. I actually had ordered these wheels a few days ago but in a +15 offset and 9.5” wide. Didn’t realize they had the other offset and widths available. Vossen has a custom sizing program, you can get them in configurations from 8.5” - 12” wide and offsets from 0 - +48mm. But I just double checked my receipt, it says 20x9.5in +15mm offset. I called the sales person to confirm because he was telling me 0 offset over the phone previously, I think he was just mistaken. He said that the 20x9.5 +15 is the STANDARD size for these. I’ll update my post. What kind of tires are you going to fit on your vehicle?
Trevor Towers Posted July 1, 2021 Posted July 1, 2021 30 minutes ago, PandonSF said: Thanks, that looks good. I actually had ordered these wheels a few days ago but in a +15 offset and 9.5” wide. Didn’t realize they had the other offset and widths available. Here are some more pictures for you as well. I included an image of my city MPG in just normal driving to show I can still maintain essentially the same MPG I was getting before. All city driving. 1
PandonSF Posted July 1, 2021 Posted July 1, 2021 37 minutes ago, Trevor Towers said: Vossen has a custom sizing program, you can get them in configurations from 8.5” - 12” wide and offsets from 0 - +48mm. But I just double checked my receipt, it says 20x9.5in +15mm offset. I called the sales person to confirm because he was telling me 0 offset over the phone previously, I think he was just mistaken. He said that the 20x9.5 +15 is the STANDARD size for these. I’ll update my post. What kind of tires are you going to fit on your vehicle? Oh nice, thanks! I have some Toyo open country at3 275/60r20 im going to put on them.
BowtieBill Posted July 3, 2021 Posted July 3, 2021 Here is mine. 2020 Silverado LTZ Z71 4WD Bilstein 6112's in front, 2" level Bilstein 5160's rear with 1" block Fuel Sledge 20x9, +19mm, ceramic coated Toyo A/T III, 285/60/20 No rub. Tires stick out past fender by about 5/8". Very happy how it came out. 1
