On 2/24/2023 at 1:49 PM, Asmith721 said:
I didn’t change gears or anything so didn’t change any setting for that portion
What is yours set at then?
3.23
Swapped out the trailrunner at for some ko2. Not gonna lie, once I got the ko2 was in the fence because the wranglers were a very good performing tire with a great look for a street truck. But 50 miles later, can see why all the love.
275/60r20 fuel vapor  20x9 +2mm
Edited by Russ757
Went with Rough Country 2" level for now with 35x11.50r20 Ridge Grapplers on stocks no spacers. Going to be towing and not a fan of spacers for towing. Did the mud flap bracket delete and no rubbing now.
Edited by Cadviking
Factory wheels and most aftermarket wheels are NOT designed to use ET lugs. You do NOT need ET lugs, just standard conical seat lugs are fine.
I had a set of General Grabber ATX's installed today. I went with stock tire size for this truck, LT275/60r20. I have to say I am very pleased so far. These actually make the truck ride a lot nicer than the OEM equipped P-rated Bridgestone Alenza mall terrains. They are very smooth, and surprisingly quiet! Would absolutely recommend these tires. Sorry for the less than great pics, but it was raining, so I was in a hurry.
IMG_5604.thumb.JPG.261a01ee2f20d7f74008813b1a759403.JPGIMG_5605.thumb.JPG.52445041b358f059fd3459d9a622e4cc.JPG
Edited by fondupot
Tons of great setups in here but I'm struggling to find lots of photos of Denalis with updated wheel/tires! Really hard to visualize what would look better than the stock setup.
I agree as I do not like my Denali Ultimate OEM wheels, I'm trying to find something else.
Yeah me either....I did see a post deep in this thread of someone who chromed their Denali Ultimate OEM, looked pretty good...but I am pretty sure I'm wanting something black with a bit more aggressive tire than the Alenza.
I have noticed Dave Sinclair's auto doing a lot of "custom" Denali...not sure the word custom is appropriate, but some of these give a good idea. However, I don't want to do a bunch of chrome delete.
Not a bad look at all...I'm not going to lift mine, just level, but still think black rims and more aggressive tires would look great.
I agree about the Alenza's, I had them on my 2019 High Country and I swapped them out for a little bit wider Nitto Terra Grapplers. I'm pretty sure I'm going to go with the 2019-2021 High Country 10 Spoke wheel in Chrome, they look nice in my opinion and really easy to take care of. While I do not like the Alenza's I'll probably run them until they need replacing because after coming from my HC with Borla Touring Exhaust, CAI and "E" tires I'm really enjoying the quiet now, I've got my Corvette and Wrangler if I need noise.
I have been looking for tires for the stock 22" rims. I was hoping for 285/55/22 but the choices are limited. Has anyone been able to find an All terrain that isn't as aggressive as the recon grapplers? On my last truck I had some michelin all terrains that where great but they are not offered in a 22". Anyone have any insight? I have been watching the forums and checking vendors for almost 2 years now.
I ran Nitto Terra Grapplers on my 2019 High Country with OEM 22", fit no problem.
That's actually a great idea re: the 2091-21 high country wheels. Those are good looking wheels and I think the chrome will look pretty sick to be honest. And agree on Alenzas, mine are only 22k miles in so no rush to get rid of perfectly good tires!!
im looking at getting rid of the 20s and doing some 18s what size are you guys doing with a level kit
was looking at 18x9 295/70/18 would that be a good fit?
    tararebecca
    tararebecca
  • Who's Online   2 Members, 0 Anonymous, 445 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
