22 minutes ago, Opiedeegs said:
Did you remove your entire tailgate for the installation
I have a GMC multi pro the wiring harness to unplug is not the simplest
No, I had just enough room to squeeze my fingers between the bumper and tailgate to install the light bar.
My fingers are too short and fat
I had quite a bit of difficulty trying to remove the multi pro tailgate
Could not get the passenger side hinge to release
I got the blade installed anyways would’ve been much easier without the tailgate
The wiring harness is nice so you don’t have to scotch lock any of the tail light wires
I have the Opt 7 with module on my Rst. Works and looks awesome only down fall is that u loose the rear bumper sensor function.  I could not figure out how to hardwire/tap in to the taillights
Edited by Nola Sciko
All other adapters will throw errors on your dash and think
you have a trailer connect when the truck is in motion. Below is the only adapter you can use with no trailer errors and backup sensors work. Trust... learn from my mistake
https://www.putco.com/529005
Will that adapter work with the Opt?
I think you need this module for the Opt7 lights.
http://www.opt-7.com/tow-package-module-for-redline-led-tailgate-bars/?sku=820-02427&gclid=EAIaIQobChMInZOOurTt4wIVCZ6fCh1iJAafEAQYASABEgKd9vD_BwE
Second that Putco is clean and simple
No wire taps
I sent in a question to the Tech Support guys at Opt7. Here is their response:
Thank you for your inquiry.
Unfortunately, we were not able to receive a screenshot from your previous message.
The module is a universal application, it will work with most vehicles.
The Triple Tailgate has 3 possible installation methods: Plug & Play; No module. Plug & Play with module and hard-wired.
Triple Tailgate Only (Plug & Play): Vehicles that do not have any of the following equipped:
-Rear Camera
-Back-up/Parking Sensor
-Trailer Assist Feature (HUD display that provides trailer connection status notifications)
-BLIS (Blind Spot Notification Signal)
Triple Tailgate + Module (PWM Adapter) (Plug & Play): Vehicles equipped with any of the following:
-Rear Camera
Triple Tailgate (Hard-wired)
-Some tailgates will only function hard-wired on certain vehicles.
* Vehicles with a BLIS or Blind Spot Sensor Systems must use the hard-wire extension kit included with the kit.
The kit will technically not be Plug & Play in this case.
**Vehicles that do not have a BLIS or Blind Spot Sensor System but do have a rear camera, rear parking sensor or a Trailer Assist System that provides heads up display status updates will require the addition of the OPT7 Optional Accessories Signal Module.
Best Regards,
Salvador G.
OPT7 Customer Experience Team
  • 5 months later...
I purchased this with the add on module for my 2019 GMC Sierra Denali 1500.  I tried the curt adapter and I tried hardwiring as Opt 7 shows in a youtube video.  Both of these installs disabled my sensors and cross traffic alert thinking I was towing something.  Does anyone have a good remedy to solve this.  I contacted Opt7 and they said just send the product back for a full refund but I really like the look of the lights but losing all safety features is a real bummer.  Anyone have success with this?  Or suggestions.
On 8/6/2019 at 8:31 PM, Opiedeegs said:
How do you install it with this harness?
No wire taps
I have a max trailer package on mine.  It has no 4 pin jack at all.  The absurdity of that aside, would the putco one still work in my case?
I can get my passenger side off easily at 45 degree angle.  Can’t get the drivers side to release in any position.  How do you get the drivers side off?  Please help!
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
