8 hours ago, econometrics said:
You're not alone, fellow Rancho victim. Lol
Hahaha,
good one .I guess I am too.
It feels like the shocks are too stiff and don't have time to dampen.
Interesting to see if a shock swap will help this situation
My truck also bounces excessively.  So much so  that one time on I-70 near Denver I had to correct the sideways bounce of the truck.  I can go to the rear bumper and bounce it up and down and when I release my hands from the bumper the truck will bounce 3+ times.  I heard many years ago that if over 1 1/2 times you need new shocks.   When i apply the brakes to a hard stop at 10 mph the truck bounces several times.   I feel it is unsafe.  My truck has 4000 miles on it, if it had 60000 I'd be replacing the shocks with heavy duty shocks.  I have an appointment next week with a local dealer but have little faith that anything will come of it.
Yep, that's how I described it to my wife and the guy at the dealership, feels like the shocks are bad, as it feels like an old '84 Buick Regal bouncing down the road at times.
On 7/30/2019 at 11:05 PM, econometrics said:
Mostly, this is just the result of trucks getting lighter, but able to carry more payload. Stiff rear ends when empty.
I agree 100%.
I wonder how bad the carbon fiber beds are going to be with this?  My 2019 Denali isn't the greatest (22" wheels/ stock 50 aspect ratio tires) and the loaner I'm currently driving (2019 2.7L SLE 4X4 without Multipro tailgate, smaller wheels & larger aspect ratio tires) is just about as bad.  Can't believe how much lighter the normal tailgate is compared to the Multipro.
Edited by Wheelguy
Mine is excessively bouncy I was going to change out the shocks. I have a 2019  regular Silverado with 4 WD.
  • 8 months later...
Bumping the thread, as I just bought a 2020 Trail Boss and I get the same sway but less now that I installed 295/70/18 and new wheels. My son just bought a RWD 2020 Silverado RST and it also sways? Anyone find out what's the issue?
Edited by Inside Man
added photo
Its a truck guys, they are designed to work meaning they are engineered to perform tasks associated with hauling loads in the bed, trailer, etc.  By default, they will perform best with a little weight in the back.  Its very hard to design an unloaded truck to handle like a car over rough roads, but then be stiff enough to support a bed loaded with a couple thousand lbs of weight.  Add in the fact that most trucks come with wheels ranging from 17 inches up to 22 inches, and there is no way to design a shock or spring system to accommodate the variables in suspension stresses based on the multitude of available sidewall dimensions (flex).  There's gotta be some understanding of what your purchasing and the intent of design for what your purchasing.  A truck riding on an 18 inch wheel is going to sway and roll significantly more than a truck riding on a equivalent diameter tire but utilizing a 20" wheel.  If you don't grasp the concept of what a truck is ultimately designed for, or don't like the "quirks" associated with making a vehicle capable of its intended purpose, then you might be better served by purchasing a Tahoe or Yukon and you will be much happier.
Edited by Gangly
Edit
  • Like 4
Yup, Ive test drivin 6 and every single one of these trucks regardless if its GMC or Chevy feels "loose" at highway speeds to the point where it makes you feel uncomfortable, its got nothing to do with shocks but the design of the truck.
I have an RST with optional 22" wheels and Bridgestone Alenzas with stock shocks and springs. Rear axle would hop on bumps, especially hard acceleration from a stop into a turn and had a vibration at 55-60. Had to be the lighter bed because 100 lbs over each wheel in the bed calmed it right down.
Once the standard shocks wore in and tires were seated at about 1000 miles took it for a road force balance at the dealer. It cured almost all of the problem the balance without the added weights disappearing by 4K miles. Now at the point where the ride is at least as good if not better than my '16 Z71 18's with more aggressive Wranglers, and stability and handling of the T1 with the 22's even at 70 mph is much much better than was my K2..
On 7/30/2019 at 11:54 PM, Wiggums said:
Exactly the same situation I was in. That is a liability issue, I was more angry over the fact I could have killed the guy walking on the side of the road. GM fanboys got all over me on this, questioning my experience, etc. "My Ford did the same" I've driven 4x4's and none were this bad. I was going about 70 km/h, maybe 80 km/h when it happened. That is why my next car isn't going to be a Chevrolet unless they address this.
Having owned both a 2019 new version and now a 2020 I can confirm they fixed this issue on the 20s
Were both RST 4x4s with twin tube shocks?
I think its more spring related .
RST owners were the only ones who had that issue, not the others. That was why I asked.
Mine was so bad it went sideways and I wasn't accelerating or braking. The back end had no traction and was wildly flailing back and forth.
My first incident was on a regular road that was caked in mud and I nearly hit a guy on the sidewalk. That was about a year ago when we had the floods and mud came from the nearby hills.
I'd have to point out that kind of ripple was not common, it has to be at the right rhythm for that to happen.
I drive on the dirt road to the ranch every day and I have run into that issue quite a few times. The Cheyenne RST is not a truck I'd want to be driving on the dirt road even at 30 mph (if it is straight, smooth, with excellent visibility). I have driven all the other 4x4's much faster than that and all handled better. I don't even drive it anymore, it has been sitting there for the past six months.
    goetzmann
    goetzmann
  • Who's Online   5 Members, 1 Anonymous, 561 Guests (See full list)
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
