What was your total cost?
We do a 2.5 kit for $550 shipped (io5) or programming for $100 if you supply parts [emoji2935]
Sent from my Pixel 3 XL using Tapatalk
7 hours ago, th3magpi3 said:
We do a 2.5 kit for $550 shipped (io5) or programming for $100 if you supply parts emoji2935.png
Thanks, and to spare me a lot of searching
parts required? I believe I need a new brain for the infotainment, but can keep everything else?
any advantage to doing it in tandem with the denali cluster upgrade?
fyi I only use the mobile site, so if you have any links in your sig, I can’t see them. The admin of this site thought it would be fine to not include a desktop format link for phone users.
Other than the cluster being an AWESOME upgrade you'll retain full steering wheel controls in Android auto and carplay.
In terms of parts you'll need a radio, HMI and USB.
Our site is https://coastalflash.com
Send me a PM or call our toll free number on the website and we'll get you sorted.
On 1/6/2020 at 11:13 PM, th3magpi3 said:
If it is the same HMI we will be able to retrofit it.
Also, thanks everyone for your patience. We've been quite slammed but this is top of mind :)
Any update on the HMI 3.0 upgrade?  I have a 2015 Denali, and was going to do 2.5 upgrade, but if 3.0 will be an option soon, I'd rather hold out for it.
Thanks! :)
ive been told the 2.5 and 3.0 are completely different systems  and cable connections are different, utilizes ethernet maybe?
would need to replace alot of hardware and complicate software. replace alot of pieces in the truck.
tech companies have been working on it, but to integrate the 3.0 and allow everything to function normal would be very expensive...... ive read
Look at the first post in this thread.. it’s already been swapped in..
Just because something has been retrofitted doesn't mean it doesn't require a lot of aftermarket work. We are currently attempting to come up with the best solution to retain as many factory features as possible. Having a fancy new HMI3 in your K series truck doesn't mean much if there are missing features.
We are doing our best to create the best retrofit we can. I know a lot of you have been asking about this - we are working on it.
We will post an update very soon.
Sorry, i dont mean to step on anyone’s toes, displaying computer info is different then retrofitting it to work with everything in the truck.
i think its pretty important to keep steering controls, seat memory,  remote start, power locks, power windows, and cluster communication with the radio and hmi.
sorry, wont comment again, just wanted to explain displaying info on the screen in hmi 3 design isnt what i described.
Thanks,
I am in for the up dates, also if needed I'd volunteer for testing. I am familiar with GM's SPS programing system & GDS2, and use it view or make changes on my own truck, if that matters.
Edited by camcamaro1991
  • 3 months later...
5 month bump...any progress on this?
  • 7 months later...
I would say no, the original poster I don’t believe is on here anymore.
I think he was Banned not to long ago ?  I could be mistaken though  ...
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
