On 8/13/2019 at 12:38 AM, th3magpi3 said:
Hey guys,
Something very exciting to share with you. A lot of people have been interested on whether or not this 2.5-3.0 HMI retrofit would even be possible in our older generation of trucks.
Well, I'm happy to say that the proof-of-concept is here for you to take a peek at :)
Like I mentioned in the video, there are still some kinks that we need to work out. Navigation is handled in a different way on the newer HMI than the previous version, and we're still testing access to other stock 2019+ vehicle applications (onstar availability, store compatibility, wifi hotspots etc.). But I'm happy to report that not only does it work on our test bench, but it also works in my 2014 (which I think is pretty sweet).
In regards to the new 3.0. Carplay and Android Auto are working as you'd expect, but they're faster and less buggy that with the old HMI's. the entire unit is just a nice face-lift and snappier to use all-around.Go test a 2019 Sierra and you'll see what I mean.
We are also working on some pretty fun unlocks and features for these units as well, so keep your eyes peeled.
I'm hoping to be able to offer a full retrofit kit for the new 3.0's in the not-so-distant future. There are a few things that need to be sorted, harnesses to be made, etc. to facilitate a seamless upgrade experience, but we're getting closer and closer each day and I figured it was time to share a bit of our progress.
Please, if there's any questions you have post them below. I'll be happy to answer ?
Thanks again for reading/watching. Feel free to PM me about any of your vehicle update needs.
*****Q&A*****
1. Does this require the HD screen? A - No. This was done on a 2014 SLE with the SD screen. However, we CAN retrofit an HD screen into the system.
2. Will we be able to provide unlocks for this generation of HMI like Video in Motion, Rear Camera in Motion, Boot Logos and more..? A - YES. We will post those upgrades and mods here as well as to their section on the T1XX area of the forum when they become available. (Hint hint, soon)
3. What hardware is required to complete this upgrade? A - Right now, there is a fair bit going on behind the scenes to make this work, and we're still not fully at 100% functionality. These units use new HD cameras, they connect to certain components differently and use some completely different components... All of this has to be taken into account when we make a retrofit kit. So while this isn't as simple as a 2.0-2.5 upgrade, we're working hard to make it as easy as a swap as possible.
Any update on this, looks like there is interest again.
1 hour ago, JimCost2014 said:
No, they are still active on the site:
Well it says BANNED  on his profile & under his name ...
Looks like he has been active as recent as Monday, who knows, maybe reach out to him at Coastal Flash to see if anything is still in the works.
  • 7 months later...
  • 4 years later...
Not sure what the FB post was about as I avoid FB like the plague it is, but  @GTPprix White Auto and Media are the best people I've dealt with in upgrading my HMI to navigation option.
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
