Let me preface by saying i'm indifferent to adaptive cruise control and more asking this from a feasibility point of view.
I was looking at the adaptive cruise control description on the 2020 GMC models and it seems adaptive cruise was implemented using the cameras rather than radar. It seems to me that 2019 models with Driver Assist II package (forward emergency braking, distance, ...) already have all the hardware to support this. Someone correct me if i'm wrong but if there is no new hardware, then it's only software.
Does anyone think GM would/could offer this for the 2019 models?
There are quite a few hardware changes to make this happen (more than you'd think ;)) if this is something you truly want to do drop us a line from our site  and we can discuss it :)
How can I reach you... got some things that you may be able to help with.
That's interesting. From the description, i assumed there were no hardware changes. I honestly don't have a need for adaptive cruise. This was more of a curiosity than anything.
Below is the reply I got... certainly not going to invest in adaptive cruise :)
its doable but its a huge job, different camera, adding a few modules, steering wheel change, cluster programming, bcm programming etc. Doable but pretty expensive :(
Below is the reply I got... certainly not going to invest in adaptive cruise [emoji4]
its doable but its a huge job, different camera, adding a few modules, steering wheel change, cluster programming, bcm programming etc. Doable but pretty expensive [emoji20]
Is that for those of us that already have the radar set following distance style of cruise control?
As far as I know, the Sierra/Silverado don't have radar. Following distance monitor, forward emergency braking, etc are all implemented using the windshield camera.
Yeah, definitely no interest in paying for it. Now, if they gave it for free, I would gladly accept. ?
Has anyone figured out a way to record the rear view mirror camera. Seems like such a waste to have to buy and install a rear view dash cam when there is a perfectly high definition functional one in the car. Maybe GM can do us a solid like what Tesla did for their customers. Tesla vehicles can now record from the cameras unto a usb flash drive. I would actually be willing to pay a little to have this feature.
I did not know that, interesting. But that camera is different then the “new” one that allows true adaptive cruise control?
I also would love to use the vehicle cameras and record them as a dash cam.
Yep, there is no mention of radar in the manual (i searched). Hopefully, we will see camera record-ability feature available soon from a 3rd party. Fingers crossed.
GM is offering Adaptive cruise in the 2020 1500 Trucks. Could always trade up!
Pretty sure my 19 only relies on camera, no radar. I would love the radar set following distance. That would work fine for me.
Tom
Shoot, you really gotta want it pretty bad to trade a one year old truck. I won’t even consider a move until the refresh and probably not even then unless some other really great things are added like a supercharger maybe...
I guess ACC would be kind of cool but if it’s anything more than a reflash, I’m out.
Adaptive cruise has been available on 2015+ GM SUV Tahoe, suburban, Yukon, Yukon xl..
The usual GM holding out on tech for trucks to add it years later to get people to buy the next years model.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
