2013 chevy 2500hd parasitic drain
Hello guys, and gals
I recently ran into a trouble with my truck, ive been getting a parasitic drain and cant seem to find whats draining the battery. I already tried unplugging all the fuses 1 by 1 and even took the stock radio out but there still seems to be a parasitic drain. If u got any idead im willing to to hear them out
