Glad I found this post before posting a question.
My ‘09 has been throwing those codes and P0442. I replaced the gas cap as it was trashed to begin with and the purge solenoid valve under the hood but still get the code every now and then. Dealership said I need to replace the vent lines as the previous owner use cheap fuel line that feels more like a balloon. They also said the charcoal canister and the “canister vent solenoid/service kit” so it relocates the filter up by the top of the transmission. Vent solenoid is cracked as the previous owner just let it hang loose. Too lazy to put it back on its bracket. If I put it on there the hose kinks and I thinks causes a whistle when I fill up.
Only issue is the parts guys can’t tell me which one I need as it shows two styles. One has a jointed section. Which should I use?
Thanks.
I apologize for hijacking the thread
UPDATE 3:
Supposedly you need any cluster OTHER THAN a WT model cluster to have full steering wheel functionality. Went back to the part truck and removed the all terrain cluster, trim, and snipped as many wiring harnesses as possible to pull out the factory terminal leads if needed 😂 that poor donor truck…
As of right now I’m relying on Darth_Vader’s thread and YouTube videos.
will update.
The “engine hours” display is there because the truck detects the key presence as you were thinking.
My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.
It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue. If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.
Good luck with it.
