I am glad I can come to this community and ask questions but so pissed off the damn dealership could not tell me. I spoke to them and they said "We will find out for you". They never called me back, and yes I rang them up a second time.
Anyways, my 2014 GMC Sierra All-Terrain - 5.3L took E85 Flex Fuel. Any car or truck with a yellow gas cap will take it.
My new 2019 GMC Sierra AT4 - 6.2L has no cap and I can't find written anywhere if I can use the E85 Flex Fuel in it or not.
Anyone know?
As I understand it neither the 5.3 or 6.2 can run e85. The reason being is ethanol absorbs water if it is in the station storage tank for extended periods especially this time of year. Once it absorbs the water it turns into a white sludge  and can clog things up. I am not a scientist this is what I was told.
The current DFM 5.3l and 6.2l are NOT E85 compatible at this time
The 2019's for the 5.3 and 6.2 are not FF.  Makes me mad that they didn't offer it.  I still run a 50/50 mix of E85 and Premium in mine.  Same goes for my 2002 Silverado.  It isn't flex fuel but I do the same, 50/50 mix.  Love the way they run with it since it boost the octane up nicely.  Not to mention I like the exhaust smell. :)
My 2014 1500 is supposedly E85 compatible. Has the bright yellow gas cap and a big yellow sticker under the hood. I've not used anything more than E10 and hope to never have to. We still have a few local stations with non alcohol contaminated gasoline and about every 3rd or 4th tank I'll try to use that. About a dollar more per gallon I think, but it makes me feel better.
That alcohol gas is terrible on my o540 airboat engine. The valve seats in these old motors need that old gas with the lead in it to keep the valves lubed. We constantly have to add 'Lead Substitute' even with no alcohol. However, the alcohol gas does make them run a little cooler down here at sea level. That's a plus.
Regards,
jumpinjoe
Regards,
jumpinjoe
We've decided that the old two stroke in my dad's boat doesn't like ethanol so we put premium in it and it runs much better.
The 2019's for the 5.3 and 6.2 are not FF.  Makes me mad that they didn't offer it.  I still run a 50/50 mix of E85 and Premium in mine.  Same goes for my 2002 Silverado.  It isn't flex fuel but I do the same, 50/50 mix.  Love the way they run with it since it boost the octane up nicely.  Not to mention I like the exhaust smell. [emoji4]
You actually use 50/50 Super/Flex and zero issues? I just started doing it with 5 gallons of E85 per tank of super
Sent from Above
Appreciate all the replies, glad I asked instead of just adding it in LOL..... Shitty they did not set the newer trucks up to run on it. My 2014 Sierra loved the E85 juice I gave her.... :)
Regards,
jumpinjoe
I ran full tanks of only E85 in my 2014 and she loved it. I did 5 tanks on Premium and 5 tanks on E85 and compared notes.
E85 cost less, higher octane, truck ran better BUT it did not get as many KM's out of a tank as the Premium did. In the long run Premium was cheaper to run. But I still ran E85 every 3 or 4 tanks. No mix, just straight.
Isn't the FF an available option? Somewhere I got the idea it was.
Regards,
jumpinjoe
Just gotta know what kind of 2 stroke motor is he running? We don't see any 2 strokes down here where we run. Thanks.
Regards,
jumpinjoe
Sent from Above
Yes,  a 50/50 mix no issues.  Been running it that way for over 3 years now.
Regards,
jumpinjoe
Sorry, that's on his ski boat, not an air boat. I can't remember for sure what he used to run on his remote control boats and air boats but I can ask him.
