Have a 2020 Chevrolet 3500 4wd.  Anybody else have the noisy steering column. Has a popping click sound when making slow speed turns.  Never hear it at highway speeds.  Always at slow speed maneuvers.  My 15 did it also but my 17 did not.  The one thing that my 15 and my 20 have in common is neither had the digital steering assist.  My 17 had the assist and didn't make the noise. Drives me crazy.
Edited by STGS
Are you sure it is in the column?  I have seen some popping in front suspension.  This is usually fixed by loosening your upper and lower control bolts and re-torqueing at ride height.  When suspension bolts in bushings don't get torqued at ride height they get preloaded and can cause noise at slow speeds in parking lots.
I have the same steering clunk at low speed turns as well on my 2020 Denali HD with digital steering. I hoped in a new ltz Silverado and the same thing...... I haven’t herd that noise since my 2006. Terrible. Goes nicely with the steering wheel wobble ??‍♂️
  • Sad 1
It's definitely inside the cabin.  I would say it's the bearing or bushing in the column. It coincides with the turning of the steering wheel at slow speeds.
I have the same sounds on my 2020 Denali HD, really only notice it at very slow speeds, and when its cold.
Yes, that is when mine is the most noticeable.
22 hours ago, Babymac said:
I have an appt next Monday to have my steering column replaced. It has a clicking sound just off of center to the left to right.
Let us know if it fixes it.  I'd rather not have them dig if it doesn't fix it. Thanks
10 minutes ago, cmysstailights said:
My 14 and 15 did it. Dealer fixed the 15.
My 15 did it bad.  Do you remember what the issue was or did they just replace steering column?
Think they wound up replacing the whole column. Let me see if i posted my results
I'm having this or similar noise. It's only really noticeable on rough roads. I drive on dirt washboard road very often, an I swear I can feel the bumps up through the steering column. You can also hear some light clanking noises as well.
Here's a video clip of the noise. Not sure how many of you drive on dirt washboard roads much, but I do somewhat often, and you can imagine how annoying this noise and the feeling that comes up through the steering. Several years back I had a new chevy with similar noises and feel. The service department told me to bring it in and they would grease the column periodically which seemed to help. I mentioned this to the current dealer and was told there is no way for that to happen as now they are engineered with sensors. Well, it's happening!
I have a 2020 Chevy HC 2500 diesel. Mine makes the same clunking noise. When the ignition is in acc mode, you can move the steering wheel back and forth and it clunks. No power going to it at all. I’ve been working with two different truck stores and the dealer. The custom truck shops believe it is a bad steering box. This has been a problem for 11,000 miles. I’m sick of it. I live in a rural area and the roads are bumpy. You can feel the clunk all the time. When you turn slightly left or right, it doesn’t do it. Only when going straight. I have a dealer appointment next week.
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 1,224 Guests (See full list)
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses more gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
