it's totally sealed up, no chance of intrusion assuming it doesn't get pried on or the housing/pad cracked..
that's the same 3M automotive adhesive that is used on your rear tailgate bowtie.
it'll hold up to car washes and harsh winters if the surface is cleaned properly first.
Yeah, I'm not really worried about it coming off.  I am more concerned with battery life and general longevity as I said it just seems really cheap.  I may be wrong...but it does only have a one year warranty.
I would assume it can be pried open and a battery replaced.
seems silly to have a thing like this that can run out of batteries then just sit there..
Still wondering if this will allow the truck to run while key fob is left in vehicle and doors locked?  Gets very cold up here in ND and leaving truck running during the winter is a must.
have you read all the responses, someone earlier said they had it and it does allow that.
I never really could understand the "dont lock the key fob in the truck" thing..  (especially with proximity lock options)..
Edited by rbrjr1
Yes reread all responses, doesn't say anyone has tried it while truck is running to see if the truck shuts off after the predetermined time frame.  All that was confirmed is that it will lock the doors with fob inside.
With the truck off, I can lock the fob in the truck. With it running, all the doors except the drivers door would lock. If I take the fob with me, I can lock the doors while it’s running.
I noticed the truck can’t be remote started with the app & the fob left in the truck either.
Why would you want to lock the fob in the truck while it’s running?
When it's 30 below outside and you go into the store or restaurant or hardware store or whatever, it's a must to leave the truck running.  Or say you're doing a hotshot out to a rig and you have to unload and you want your truck locked so the other rig pukes don't steal your stuff.  There are infinite situations where you would want your truck running longer than the 10-15 minutes allowed.
I totally agree about leaving it running but you asked about leaving the fob in the truck while it’s running. Why not just take the fob with you & lock the truck while it’s running. It’s a nonissue then.
If I'm not mistaken, i believe that the truck will, no doubt, shut off without the fob.
Nope. You can leave the truck locked & running without the fob in it. I do it all the time.
I do this all the time too while visiting job sites as my dog comes with me to work. In the summer heat and winter cold, I leave the truck running if needed for him. The truck with the fob in or out only runs for 15min or so and shuts itself off. It’s probably an anti idling thing, but it’s annoying. My last truck, I’d leave the keys in and lock the truck with the app on my phone.
Good to know, thanks. I wasn’t aware that there was a time limit on how long it will idle, other than when remote starting. I’ve never had mine shut down on me but I don’t let it idle that long either. 5-10 minutes at the most.
I've been known to shut if off, get out, lock with fob and then do a remote start while walking into store.
Doesn't solve the length of idle issue, but will keep heater running til the time-out.  Usually long enough for a quick stop.
I finally got this programmed & installed. Not thrilled with the shape of it. It doesn’t look like the one pictured on GM’s website & it doesn’t quite look right on the truck, IMO.
It does work good & it has held up to touchless car washes & power washing though. We’ll see how long the battery holds up.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
