Can someone post a picture of where the small fuse box is mounted?
My switch and harness arrived today.
Thanks
George
Thanks
George
Goes kinda under the steering wheel behind the trim panel. It’s the blue box in this diagram!  You installing yourself? Good luck!
Thanks!
I did most of the install.
I bought the new knee bolster but decided to use it to make a template and just cut the hole for the switch.
I ran the wire across the engine compartment and through the grommet.
I didn’t get started until 5:30 and ran out of light.
Tomorrow I will find the end of the wire under the dash, put it in the plug and then connect the battery end.
It took me around two hours so far... The last 1/2 hour was spent searching for the power wire in the driver’s knee well. I should have given up and waited for daylight.
It will also probably help to have a second person move the power wire while you’re under the dash so you can see it easier.
I’m going to hook up a ham radio, an air compressor and eventually some extra lights.
31 minutes ago, kf9yr said:
Thanks!
Nice work! The hardest part is definitely installing the new knee bolster as the whole dash has to come apart so good call drilling a hole in your current bolster!  Have a few lights hooked up to mine so far, probably going to add some more with a back rack!
Does the 5th switch always have to be used for snow plow prep? I would like these for adding some auxiliary lighting. I don’t have any need for a snow plow so it would be nice to use that switch for something else.
No just have to find the wire that feeds the beacon
Sent from my Moto Z (2) using Tapatalk
is this an option on the Denali or factory?
Not sure what u mean but u can get it on all models from the factory
I purchased a 2020 2500 Denali about 2 months ago. I'm not sure if it's because I live in Canada but there was no option for upfitters switches. I didn't know they where available until I found this thread. For reference I have the snow plow prep package and 5th wheel prep.
Did you custom order it from the factory? It should be available for U.S. and Canadian markets.
If you "build" a truck on the Chevrolet website you should see it listed as an option to select.
Yea it’s an option on the Canadian trucks as well!
His is a Denali. It’s not available on the Denali build in Canada.
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
