Maybe once mine is clean Ill post a pic so you know how to "grampa-tize" one by adding a topper..... :)
Funny, I feel the same way about my bimini top on my boat :D
Wow! Very nice!
Thank you for sharing :)
man, that looks like a different truck with the lift! I really like it...
Edited by MacLaren
On 1/11/2020 at 6:59 AM, lt1z said:
Pacific Blue but same code ?
What did you do for tint? Mine goes in tomorrow and I am torn. Not sure if i want to match the back or go darker all around.
35% on the fronts. Stock tint in the back.
Wound up doing the same. She's dirty, but came out nice!
Since I've seen all of the fancy Northsky Blue trucks you've posted on here, I thought I'd share a picture of the cheaper model that I just picked up Yesterday.  :)
Here's my 2020 Silverado Crew Cab, Regular Bed, Custom Trail Boss, with the roll bar and black running board steps.  I'm digging the looks of this truck, especially how the roll bar blends in the lines of the bed to the cab.
On 1/15/2020 at 7:08 PM, Roy2895 said:
Here's my girl.
That is a Great Looking truck!!!
On 12/14/2019 at 5:36 PM, MacLaren said:
I saw the Silver Satin thread and, thought why not?!
At any rate, I love the NorthSky Blue color and I thought it would be a good thread to check out
So, all you NorthSky Blue Silverado/Sierra owners, let's see em!
Your paint looks ? what are you using to get that shine? Looks wet in all 3 pics
Thank you :)
It was ceramic coated. And , part of that process is to give her a good polish.
13 minutes ago, MacLaren said:
Thank you :)
Looks nice MacLaren.  I put F11Top Coat spray on mine and it has a deep wet mirror bright look.  Easy to apply, easy off and beads water for months.  Very easy to wash.  24 hr. cure time.  I hear the aircraft quality Aerolon Tech Shine is awesome as well around $30 a bottle. It's applied to a wet finish and water activated.
Man, that looks AWESOME.
I also, cannot wait to get those 22's that you have there! They looks so darn good!
And, thank you!
Edited by MacLaren
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 705 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
