8 hours ago, swathdiver said:
There's no replacement for displacement man.  Most hi-power mods to a naturally aspirated motor come at the expense of street manners.  For all the money you spend to coax another 100 horsepower out of the 5.3, you could have just gone with a 6.2 or larger motor.
6.2 has an extra 60 hp and its heavy but yet again I'm just learning I know its a bigger motor u can bore it out blah blah
Edited by Slowarado18
Spend more time learning and less time asking.
  • Like 3
I’ve owned a few blown gas trucks. For the money drivability and longevity couldn’t be happier. My 92 is more radical than that I’ve had it 10 years just maintenance. I bought it off E-bay already done. I expected to have to do a rebuild, hasn’t happened yet. I even run the small pulley sometimes. Do the research. Especially if you’re a do it yourself type. You can do a kit in one weekend. Quicker than going inside the engine with better results.
I installed a supercharger on my 18 5.3 added tons of power couldn’t be happier.
3 hours ago, Slowarado18 said:
These trucks are to new and not enough info about reliable parts so yes I'm asking for opinions and sets ups people do and dont like ect. And all .motor will wreck a 5500 lb truck how? I come from the custom frame and suspension world not modifying engines thanks keyboard warriors
FOR YOU INFO  therea only 1 local guy boosted pushing 1000 hp with a 16 gmc . So how the **** is 1 guy gunna have all the info if I listen to everything he has we would have the same build.......
another thing I'd like to know is what also needs to be switched I know stock cats need to be replaced with high flow . What other random crap like that needs to be considered
How much 'all motor' do you want?
You have to pick a hp/tq number and set that as the goal. Then you have to decide if your budget will handle it.
Not hard to blow $20 or 30gs screwing around with stuff like this. I'd strongly suggest making damn sure you know exactly what you want, else you're going to blow your budget all to hell.
IMO, you'd be waay better off dropping the 'all motor' idea and just putting a supercharger kit on it. Waaay easier, waaay less screwing around, more reliable and waaay better for the street, towing etc. Less money in the long run as well.......There are a few different supercharger options out there.
Lol at custom frames and suspension world.
you obviously don’t come from the motor building world.
any sort of all-motor build, aka NA build, involves making it breath as much as possible. Cams, heads, exhaust, intake, etc etc etc. They all produce hp by allowing the motor to breath. When you allow a motor to breath it moves the power band to the right. It sacrifices low end hp to make hp up top.
This is great in a sports car, but horrible for a 5500lb truck unless your going high stall race only truck with no streetability. Can you make 800hp NA, sure, but it will ruin the streetability. That is why you don’t see NA build trucks.
Now I’m not talking about bolt on, I’m talking about legit NA builds.
but being a real enthusiast, and not a keyboard warrior, you must already know all this
The LT platform has been taken to it’s limits 100’s of times, you can find this info out on corvette forums and camaro forums. You surely knew that as well.
its looking like na is a waste of time and to expensive a supercharger maybe the route to go for daily driving and less maintenance compared to turbos
I think you mean a L82. never heard of a L85. You might want to change the title.
If you have Flex Fuel then you have a L83.
If you don't have flex fuel and its AFM its a L82
ok thanks
BlancoSilverado, my 17 has the L83 non flex w/afm. Perhaps this is different for other years. I even requested a build sheet from GM to be sure. It states the block is indeed L83. Can you shed some light for me?
Sent from my SM-N975U using Tapatalk
Back to the original topic and ask. . . .
I know I've said it in dozens of posts. It is much cheaper, safer and more reliable to just SC your truck. Coming from experience you'll easily save $24,000...
Here are websites I've used for parts and information getting into the GM Gen V platform.
https://www.onallcylinders.com.
This is an awesome site to look at specific engines, their specs and some build suggestions.
https://www.gmpartsdirect.co/auto-parts/2014/gmc/sierra-1500/denali-trim/6-2l-v8-gas-engine
Great for stock parts or some budget friendly upgrades like Injectors, fuel pumps etc.
https://www.carid.com/2014-gmc-sierra-denali-accessories/#spb_exterioraccessories
Great resource for ALL types of parts for ALL types of vehicles.
https://www.jegs.com. and/or https://www.summitracing.com
Perfect for sourcing anything stock or aftermarket. I usually purchase my Oil and Meth (Boost Juice) from here.
https://www.texas-speed.com
pioneers in many GM LS based items. Top or bottom end solutions.
https://gwatneyperformance.com
Great for some really niche solutions such as true drop in piston/rod combos that will bulletproof your Gen V Block.
https://www.briantooleyracing.com
Classic resource for cams and fuel management delete kits.
https://www.rockauto.com/?a=G
rock bottom prices and a good source for replacement parts.
Here are some popular power adder websites:
http://performancefueled.com/trick-performance-turbo-kits/
trick turbo system
https://whipplesuperchargers.com
Whipple SC's
https://treperformance.com
This is the best site I've found for prochargers, upgraded components and price of kits.
I'm sure I've missed things, this should be a great springboard for anyone wanting to look into upgrades.
trick turbo system
Whipple SC's
this is exactly what I wanted thank you very much I knew there was. at least 1 person on this website that actually knew information ?
Many of us have been around the game long before these direct injected engines. It's just that some may not want to do someones homework for them is all. ?
This guy will end up doing a CAI and a crappy cat back plus some cheap zero HP parts.  Very easy to sniff out a dreamer.
  • Haha 1
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
